richparks Posted November 4, 2016 Posted November 4, 2016 Hi All, I've just purchased a 2009 370 GT Edition, I previously owned a 350z before moving to an E92 M3 and then a 320d (don't ask). I had a quick few questions as I always have when getting into a new car and you start to hear all kinds of different noises. The most pressing concern I have are the noises at low speed - when pulling in and out of the drive etc there is a kind of scraping, but it doesn't look like anything is anywhere near actually scraping the floor. The second is at idle and low revs there is a lot of rattling coming from the exhaust it sounds like and tends to go away when under harder acceleration - unless I just can't hear it over the engine! I've done a few searches and heard a few rattle problems but all seems to be when at 4k revs plus. My first guess would be something is slightly loose and when the exhaust is cold its rattling more than usual and at the low speed i can hear it more clearly + sound bounce back from the side of my house on the drive. The scraping thing I have no idea what it is - is this a common problem? Might just take the car to Horsham, get a service and a general check over for peace of mind.. Thanks, Quote
JurassicZ Posted November 4, 2016 Posted November 4, 2016 I would take it to Horsham Developments, top guys Quote
Hodaka Posted November 4, 2016 Posted November 4, 2016 No idea bout the scraping, but whereabouts on the exhaust is the rattling coming from? If it's towards the front/middle then it could be the heat shields on the cats rusting off? Happened to mine, so it would rattle at low RPM. I used some jubilee clips to secure it on, until I save the funds to get HFCs. 1 Quote
WINKJ Posted November 4, 2016 Posted November 4, 2016 they always come crawling back in the end! :evil: Quote
Dracostan Posted November 4, 2016 Posted November 4, 2016 I've noticed that in cold weather the factory Bridgestone front tyres have a tendency to 'crab' on tight turning, making a low frequency noise I can only describe as 'crumping' Does this sound like the sound you're getting? Quote
richparks Posted November 5, 2016 Author Posted November 5, 2016 No idea bout the scraping, but whereabouts on the exhaust is the rattling coming from? If it's towards the front/middle then it could be the heat shields on the cats rusting off? Happened to mine, so it would rattle at low RPM. I used some jubilee clips to secure it on, until I save the funds to get HFCs. Yeah I think it's about the middle - it's actually worse than I first though after driving it yesterday it's louder than the exhaust half the time and it sound like I'm driving a completely broken car Quote
nissanman312 Posted November 5, 2016 Posted November 5, 2016 I've noticed that in cold weather the factory Bridgestone front tyres have a tendency to 'crab' on tight turning, making a low frequency noise I can only describe as 'crumping' Does this sound like the sound you're getting? Yeah that's horrible Can't wait to wear mine out and get some decent rubber on them Quote
richparks Posted November 5, 2016 Author Posted November 5, 2016 Yeah it's when i turn sharply or go over a small driveway curb (1 inch) makes a noise but also I can feel it through the steering wheel as if I've hit something. The banging in the middle seems to be a lot better once it's warmed up, it's horrendous on a cold start - hoping it's just something needs tightening Quote
Richf Posted November 5, 2016 Posted November 5, 2016 It will be a GT not a GT Edition . the noise could be a cat or heat shield rattling , H-Dev should be able to sort it for you they keep stocks of used Cats and once on the ramps I'm sure the other issues will become apparent Quote
richparks Posted November 12, 2016 Author Posted November 12, 2016 (edited) I think this is the rattling problem - pretty sure there should be jubilee clips holding these together...? https://goo.gl/photos/ceVH5QdDj25Z8RCS9 Edited November 12, 2016 by richparks Quote
Alpinaman Posted November 12, 2016 Posted November 12, 2016 Congrats.. I have a brake disc shield that was very close to the disc,on little bumps it would make a weird twang/scrape noise.. Easy fix.. Quote
richparks Posted November 12, 2016 Author Posted November 12, 2016 They look spot welded on to me. Had quite a bit of movement even on touch - I've just bought invidia Gemini to replace anyway - should hopefully fix whatever it was. Thanks Quote
Hodaka Posted November 12, 2016 Posted November 12, 2016 I've just bought invidia Gemini to replace anyway Great choice Quote
