jimmy.farrow7 Posted August 5, 2016 Posted August 5, 2016 I think my battery in my key fob is on its way out, is it a simple task of buying a battery and changing it over or does it have to be reprogrammed. If i change it over can it cause problems, i have a JDM 2 button key fob Quote
Ridz Posted August 5, 2016 Posted August 5, 2016 I changed my Zed key fob battery a couple of months ago, without any problems. If you change the battery over quickly enough, I found I didn't need to reprogramme. However, mine is a UK Zed, but I would have thought all key fobs were the same. Hope this helps. Quote
The Trouser Posted August 5, 2016 Posted August 5, 2016 I think my battery in my key fob is on its way out, is it a simple task of buying a battery and changing it over or does it have to be reprogrammed. If i change it over can it cause problems, i have a JDM 2 button key fob Its a simple task of just changing the battery. I bought a pair of batteries a few months ago - you're welcome to the spare if you want it - PM me and I'll post it to you. TT Quote
Gerry40 Posted August 10, 2016 Posted August 10, 2016 (edited) This was the first type of topic I read before purchasing my Zed in October last year and sure enough one of the key fobs had a flat battery. I'd prepared myself for the worst after buying 2 new Duracell replacements ( a re-sync of both fobs ), changed the dead fob first and to my pleasant surprise it worked without any re-programming etc, the battery had been removed for a few days as well. I then replaced the other one and was chuffed I'd avoided any of the problems associated with replacing the batteries, maybe I was just lucky. Edited August 10, 2016 by Gerry40 Quote
Zeezeebaba Posted August 10, 2016 Posted August 10, 2016 Replaced both of mine a while back, no issues either. Quote
MikeyM Posted August 10, 2016 Posted August 10, 2016 Out of interest.. what battery is it, as in what number so I can look it up and order one myself Quote
Ricey Posted August 10, 2016 Posted August 10, 2016 Out of interest.. what battery is it, as in what number so I can look it up and order one myself 2016 I had to buy one for that zed I detailed the other day Sent from my SM-G925F using Tapatalk 1 Quote
Ricey Posted August 10, 2016 Posted August 10, 2016 BTW reprogramming is a piece of piddle should you ever get stuck Sent from my SM-G925F using Tapatalk 1 Quote
Ollydykins Posted August 14, 2016 Posted August 14, 2016 (edited) BTW reprogramming is a piece of piddle should you ever get stuck Sent from my SM-G925F using Tapatalk Yet again Ricey I require your expertise it would seem, I need a fob re-programming/copying will add it to the list? Edited August 14, 2016 by Ollydykins 1 Quote
Erni902 Posted August 14, 2016 Posted August 14, 2016 Had the same issue with mine when I bought it, both key fobs dead. Paid £1 for replacement duracells from B&Q and now all singing all dancing. CR2016 is the battery. Quote
