I have been toying with the idea of getting a true dual exhaust before I go for a dyno.
I currently have a Fujitsubo exhaust (Centre section and Back box) a HR y Pipe and APS decats.
Question is would it be better from a forced induction point of view to have a dual setup or stick with my normal setup?
Would I gain anymore from having one setup over the other?
Thanks Alex,
when you say other mods are there any more other than the below I have to see an advantage?
Vortech V2 S/C 3.12 pulley with CAI, FRS, Plenum Spacer, 600cc Inj, GT maf and usual stuff that goes with all that
Single exit makes a lot more power but a lot more noise, not quite the question but if you're chasing power you should consider it. Otherwise just get what you like the sound (literally) of.
Posted (edited)
Its a K&N RX4?? that goes out to behind front bumper, stock internals, no dyno run yet everything's fitted just seeing if its worth swapping exhaust while im at it if it will make a difference before tuning.
Was looking at single exits but then renders my custom rear bumper almost pointless :doh:
Not chasing numbers really as still on stock internals so just seeing if I would lose out over what I have if I did swap.
They look so pretty and sound so good :teeth:
Edited by jumping350
Not much gain to be had with the True Dual on your present set up, however if you require an exhaust now, then this would be an ideal time to fit a true dual because this time next year you may be considering twin turbo. :lol:
  • Like 2
Motordyne shockwave tdx2 gets my vote for sound and quality, I think Ian / mouthwash would agree! :teeth: My set up is similar to yours and I'm making good power, around 412 bhp @ hubs = 447 bhp @ fly :thumbs:
If you can stomach the cost for it, it's the only choice. :lol:
If yours is similar to mine and got those numbers I would be happy with that :lol: yeah the motordyne one gets loads of praise but my pockets are too burned already for that :nono:
