Air bag warning light flashing.....
Anyway the airbag light came on before, iv done a reset (peddle dance) and it's still not working and the light is still on....
Thinking its a sencer has anyone ant ideas or is it a plug in job?
Thanks guys
The pedal dance doesn't reset the airbag light; it resets the CEL. Before you reset the light, it might be a good idea to find out why it's flashing in the first place.
Try pulling the airbag connector underneath the passenger side blowing it a little incase any dust in there (I found it a b**ch to get to) then do the pedal dance. That fixed mine, mine got knocked when a bottle of Coke rolled underneath there
  • 4 weeks later...
I had this problem on mine. It turned out to be a bad connection in the plug under the passenger seat for the side airbag. With the ignition off, I simply cut out the plug and reconnected the wires using heat shrink butt connectors. I reset using a computer. Havnt had the problem since :-)
