Washers
Kieran_ctr
Now this may sound like a daft question but i used my washers to spray my wind screen & nothing came out, so I filled the washer tank up & tried again but nothing! So I have looked for the washer jets to see if they are connected properly & I can't find them! Where the hell are they haha! Need to see if they are connected because when I pull the lever back it doesn't even make a noise but my rear window is spraying water.
Sorry about the daft question but I can't see out my window when driving due to all the grit that's going down now so having to keep poor water on it :(
There are various reasons why your front windscreen washers wouldn't work:
  • Fuse gone (in which case your rear wouldn't work either as it's a shared fuse AFAIK).
  • Washer motor pump gone (most likely in your case as you say you cannot hear the motor anymore).
  • Blocked or disconnected pipe (if it's blocked you'd still hear the motor/disconnected then you'd see a puddle of screen wash eventually appear under the car).
  • Blocked return valve (usually still get a dribble from the washer jets) or simply no screen wash in the reservoir (you've already checked that & topped up).
There are separate washer motor pumps for the front & rear windscreens fyi.
The pumps are both fixed to the washer reservoir located on the drivers side in the lower bumper section just in front of the wheel/tyre behind the wheel arch liner. If you cannot hear the motor running then it is most likely the pump motor has died imo.
I went through 1 front windscreen washer pump motor & two rear ones during my Zed ownership (fairly common especially as the 350's get older). It's a fairly simple job to replace them although it can get a little messy if you've a full reservoir of screen wash.
You can get the washer pumps (both front & rear) from various places but I've found Clark Motorsport (a trader on here although other traders are available) to be very good & fairly priced.
Link: http://www.clarkmoto...ake=Nissan 350Z
More threads on the same/similar subject:
http://www.350z-uk.c...washer-problem/
(this thread has even more links in it provided by me ;) ) http://www.350z-uk.c...42-washer-woes/
Also I forgot to mention: the tubing & the non-return valve for the front windscreen washer jets are located underneath the windscreen scuttle panel. You can get at some of it from inside the clutch/brake reservoir cover location although I still think the pump is your problem.
Hope that helps. :thumbs:
  • Like 3
Sounds like your pipes are connected the other way around?
Does both front and rear screen washer works? Pull for front and push for rear.
They both have a separate pump and if either one don't make a sound, you might need a new pump. If they do, check the value which is located on the driver side, just under the cover. These no-return valve can be faulty and you can replace that with a normal connector (halfords) I think it's 2.5mm size.
one thing worth checking, on my old car ( a mondeo...) i sent it in for a full service and when it came back the washers had stopped working.....after a bit of searching, i had found that the screen wash the service place had used, had not mixed well with what i had existing and turned the whole lot to jelly....had to dump the lot, and clean the internal filter
