Summit Racing Chassis bracing £75
shire350Z
I took this off my zed as where I live is just surrounded by speed bumps and was sick of keep catching it as my cars so low, the bottom side is quite heavily scratched but there's no damage to the structure or any break in the welds, was sorry to take it of as it definitely helps with the ridigity of the car.
What Summit Racing say .....
SUMMIT reinforce equipments improve chassis rigidity and reduce the flex. By using
a monocogue aluminium triple tube shaft and forged parts. Which are not only lightweight but are also exceptionally strong. SUMMIT more upgrades the chassis performance and there by improves handling.
This strut brace is 50% stronger than other type of brace because the SUMMIT Brace is not hollow, it has 3 to 4 layers of tubing inside the brace.
£75 but would rather someone collect just due to the size of it
More parts for sale in other ads
I can check tonight but I'm sure it would fit in the zed, comes with two of the fixing bolts as these are specific with spline ends on which slot into the body, the other two are just standard 17mm or 19mm Bolts so you'll just need to get to of them buddy
