Stalled and wouldn't start up again! MotoGP
Hi,
Travelled to the MotoGP in the zed, close the event I went to move off from a set of lights in third my accident. car stalled, no worries...I'll just turn it on again... but it didn't! took 4 attempts to get it going.
Car obviously warm, each try didn't even feel like it even cranked the engine over. 5th time it sprung back into life like normal.
What could of this been?
race was brilliant albeit very wet!
Thanks
Ian
Mine did this not too long after I bought it. Never thought anything more of it until about 6 motnhs later it did it a couple of times on the way home from work - plugged it in and it was the camshaft sensor - so worth plugging it in and see if any codes are being shown
  • Like 2
Mine has done this a handful of times in the 3 years I've owned it. Mine tends to cut out randomly and go into a slight limp mode then won't start for the first two or three tick overs then starts no problems. Seems to happen about once a year :wacko:
Had it looked at a few times and nobody can find anything wrong. I always just assumed it's a dodgy sensor somewhere or something.
Pedal dance will bring up any fault codes and you can reset the ecu with it too.
To be fair tho unless you fancy sitting at the pedals for half an hour with a stopwatch trying to get the timing of the pedals right (been there done that), it's probably not a bad idea.
Is the check engine light on your dash even highlighted?
Posted (edited)
Good shout, thinking about it my camshaft position sensor failed about a year later, after it failed to restart when I stalled (dash light came up) and it used to hesitate at high revs sometimes, think the two must've been related. Been smooth since.
Edited by Jp606
no dash lights apart from the stupid air bag light. which refuses to turn off even with the key dance! it could well be a cam sensor issue. TBH it needs all its belts changed and i might look into getting the timing done on the car. valves make a little noise on start up for 0.5secs. needs to TLC
