PAWL3Y Posted July 26, 2015 Posted July 26, 2015 I have recently moved my Pioneer Avic-f930bt from my old car to the 350z. Unfortunately in the process the connector for the GPS module got stuck in the back of the head unit. In a frustrated attempt to remove it, the connector and housing have torn off the motherboard - fantastic news! What are my options from here? I was hoping I could simply strip the wire from the GPS module and solder that to the motherboard, would anyone know if that's even likely to work? Far from an expert with this so sorry in advance for any stupid questions Back of head unit for comparison, GPS connector is middle right of this picture. Quote
Stutopia Posted July 26, 2015 Posted July 26, 2015 I'd say it's probably your only shot given the damage, so you may as well give it a go, but obviously be careful soldering as you don't want to upset anything nearby. Quote
Angrybiker Posted July 26, 2015 Posted July 26, 2015 Pretty intricate if it's your first time soldering tho Sent from my iPhone using Tapatalk Quote
richard.hezlett Posted July 26, 2015 Posted July 26, 2015 Doesn't look too bad to me. Can u just set the gps connector back on the board and then just melt the solder to make the connections. Are there only the 2 connections,1 at the back and 1 on the right. Quote
PAWL3Y Posted July 26, 2015 Author Posted July 26, 2015 Stripped the GPS wire and tried placing it on the motherboard to get a connection but couldn't get a consistent signal, decided against risking soldering it so have just gone without for now. Have contacted a nearby Pioneer repair centre to see if they could offer anything, although it'll probably cost more than it's worth. As for now i'll just have to learn how to use one of these mystical devices... Quote
GMballistic Posted July 26, 2015 Posted July 26, 2015 You could always try B&B Audio Concepts just off Penarth Road to see what they can do for you. Link: http://www.audioconcepts.co.uk/ They've done a couple of high end installs for me and also helped with a few issues. Once I had a problem with one of my head units and they sent it off to a professional Pioneer repairer for £25-£35 odd I think it was. Turned out to be un-repairable but still that wasn't their fault. Quote
