d95gas Posted July 22, 2015 Posted July 22, 2015 Guys, Recently got some 370 OEM Rims, and needed to get the 370 Wheel nuts to go with them. Manage to source some, but wondering if anyone can confirm that the below, is the same shape as the 370 oem wheelnuts. I believe the cone is different on the 370, so important I get the right one's...... Quote
sipar69 Posted July 22, 2015 Posted July 22, 2015 I think you need specific OEM spec nuts for the 370 OEM whells because they have some sort of built in washer type gizmo. https://www.z1motorsports.com/g37_370z/product_info.php?products_id=5416 Quote
davetstan Posted July 22, 2015 Posted July 22, 2015 Yes they do, I recently removed 4 to fit some lockers and they looked different to the above. Drop Cs a message, he will confirm. 😄 Sent from my iPhone using Tapatalk Quote
d95gas Posted July 22, 2015 Author Posted July 22, 2015 Cheers Guys, Yep its been confirmed by the supplier that they have sent me the wrong ones, however they now need some measurements off the orginal which I dont have. They requre to know the diameter of the stub that goes through the wheel, and the length down to the collar. They are under the impression they are 1.5 pitch, but everything I look at says 1.25 Quote
sipar69 Posted July 22, 2015 Posted July 22, 2015 Is the supplier providing you with OEM wheel nuts with the built in washer thingy? If not I'd spend some time reading the forums in the U.S. I'm not an expert and I'm just regurgitating what I've read elsewhere but the impression I got was that using anything but the OEM ones is asking for trouble - ie potentially very dangerous. Quote
d95gas Posted July 22, 2015 Author Posted July 22, 2015 Yep they have admitted they have sent out the wrong nuts and are going to provide the ones with this washer bit on it and looks totally different to a standard wheel nut. I spent hours on the american forums, probably reading the same material, and the emphasis is on getting the correct one's or watch your wheels come falling off !!!!! Quote
sipar69 Posted July 22, 2015 Posted July 22, 2015 Ok mate. At least your wheels won't fall off then Quote
d95gas Posted July 22, 2015 Author Posted July 22, 2015 Least of my problems I am sure work is going out of their way to make sure I dont have time to have the pleasure of driving the car..........soon as them numbers come up......I will wave bye bye to them 1 Quote
Taff Posted July 25, 2015 Posted July 25, 2015 I've got some spare oem wheel nuts from when I fitted locking nuts, so I will take a photo & with a bit of luck I'll figure out how to post it on here so you can see what they look like. I'll also measure it up, I know that the thread size is M12x 1.25, but I will add the overall dimensions to see if that helps. Keep your fingers crossed that I can do this right & you should get a reply a little later. Quote
d95gas Posted July 25, 2015 Author Posted July 25, 2015 I've got some spare oem wheel nuts from when I fitted locking nuts, so I will take a photo & with a bit of luck I'll figure out how to post it on here so you can see what they look like. I'll also measure it up, I know that the thread size is M12x 1.25, but I will add the overall dimensions to see if that helps. Keep your fingers crossed that I can do this right & you should get a reply a little later. would be very useful if you could Quote
Adrian@TORQEN Posted July 25, 2015 Posted July 25, 2015 (edited) These are the OEM nuts for 370z Edited July 25, 2015 by octet@TORQEN Quote
Ebized Posted July 25, 2015 Posted July 25, 2015 I would be worried about what your supplier sends you now as its vital you have the correct ones. Saying this after I have experienced spacers being supplied with soft alloy nuts that not only easily chewed up taking them off and on, but became obvious their strength was highly questionable under load. I would ask for your money back on those supplied and source the correct nuts from a reputable source. Quote
Taff Posted July 25, 2015 Posted July 25, 2015 Those are the exact same ones as mine, so looks like the problem is solved. Quote
Adrian@TORQEN Posted July 25, 2015 Posted July 25, 2015 Got an OEM used set coming for you, free of charge 1 Quote
d95gas Posted July 25, 2015 Author Posted July 25, 2015 Bloody hell what a guy totally blown away with your generosity, thats what you call going above and beyond, its what makes this forum and its traders 1st class. But I insist on making a donation of some sort, even if its just the "Sticky Bun" fund, seems only fair. really appreciate it and you have certainly secured my business in the future. Massive thanks :clap: :clap: :clap: 1 Quote
Adrian@TORQEN Posted July 25, 2015 Posted July 25, 2015 You really don't have to! There is a Donate button on the top right on the forum, feel free to donate there if this is what you want and I'm sure the Admins will put it to good use / cause Adrian Quote
d95gas Posted July 25, 2015 Author Posted July 25, 2015 Thanks Adrian, really do appreciate it, do you want me to arrange collection or do you still have my address on file from the undertrays' Once again many thanks, you just kicked our holiday off to an excellent start Quote
Adrian@TORQEN Posted July 25, 2015 Posted July 25, 2015 You just go and enjoy the holiday, I'll take care of the rest! P.S. I'm on holiday too, on the beach as we speak Quote
d95gas Posted August 5, 2015 Author Posted August 5, 2015 Back off hols now...... You still on the beach Quote
d95gas Posted August 7, 2015 Author Posted August 7, 2015 Can anyone please advise of the overall length of the 370 wheel nut please, getting pretty desperate for a set now. Thanks Quote
davetstan Posted August 9, 2015 Posted August 9, 2015 Just dug out the ones I replaced with locking wheel nuts. As near as damm it 4cm top to toe. Dave Sent from my iPhone using Tapatalk Quote
d95gas Posted August 9, 2015 Author Posted August 9, 2015 Cheers Buddy, Adrian has kindly donated a set to the cause, so wont be long before I can get the 370 rims on my 350, but apprecite you taking the time to post Quote
davetstan Posted August 9, 2015 Posted August 9, 2015 No problem pal. 👠Sent from my iPhone using Tapatalk Quote
