DJ350zUK Posted June 23, 2015 Posted June 23, 2015 Hi Guys I'm after an adjustable toe arm. I allready have camber and traction but I can't seem to get to a neutral camber without it. I can't find any for sale in the UK. PLEASE HELP ME!!! Quote
Adrian@TORQEN Posted June 23, 2015 Posted June 23, 2015 Have a look here: http://www.350z-uk.com/topic/94634-torqen-350z-full-spl-range-best-suspension-upgrade-parts Quote
Grundy Posted June 23, 2015 Posted June 23, 2015 (edited) Traction Rod - http://www.driftwork...dling-pack.html *Edit, mis-read* Edited June 23, 2015 by grundy225 Quote
evilscorp Posted June 23, 2015 Posted June 23, 2015 Or get the spc rear toe bolts and elongate the hole to give better toe adjustment. Just done mine Quote
DJ350zUK Posted June 23, 2015 Author Posted June 23, 2015 Thanks guys. Not sure I'm confident elongating the hole but I like the cost side of it lol. The rest of the arms seem very expensive. I think I could make arms cheaper so might give it a go. Thanks anyway! Quote
evilscorp Posted June 23, 2015 Posted June 23, 2015 You can make an arm but you can't follow a template? http://www.350z-uk.com/topic/64159-scream-if-you-want-to-go-faster/page__st__280 Bottom of page. You get a template that sits in the gap and you just mark it out, best to use a dremel as a normal drill probably wont fit unless you have the whole innards out like I have. Quote
harryjackson Posted September 11, 2015 Posted September 11, 2015 Traction Rod - http://www.driftwork...dling-pack.html *Edit, mis-read* Does the driftworks traction rod replace spring bucket arm? Quote
ZMANALEX Posted September 11, 2015 Posted September 11, 2015 Traction Rod - http://www.driftwork...dling-pack.html *Edit, mis-read* Does the driftworks traction rod replace spring bucket arm? No. 1 Quote
