Hi
Basically what's going on is that my zed don't accelarates as it should be, i press the pedal to the bottom and he don't responds the way it should, almost like he gain and loses power, I've talked with a family member and he said might be a sensor but if it is wich one!! If someone could help me i would be much appreciated as i want to get rid of this problem.
Enviado do meu GT-I9505 através de Tapatalk
Do you mean it hesitates?
Could be a load of different things pal. You need to get to a mechanic with a decent diagnostic.
Your friend might be talking about the MAF sensor but it could just as easily be a duff plug or coil pack
does the traction control light come on?
I'm always driving with the traction control off so the light will be on, but it doesn't matter if i have it on or off.
No, sometimes u press at full the accelerator and u feel it has the power it should be and other times looks like I'm driving a 1.6l, it just don't pull as it should be, my uncle is a mechanic, we checked with the diagnosis computer and it has no errors.
We couldn't find yet the problem so was wondering if this happened to someone else
to be fair, if a mechanic has already looked at it and been unable to spot a fault then its fairly unlikely that forum members will be able to accurately diagnose the problem just from your description of the problem.
Best bet now I think, would be to take it to someone who specialises in these cars
Good luck with getting it fixed soon, must be frustrating.
Posted (edited)
could be any of air, fuel, or spark.
air - faulty MAF, clogged air filter, dead animal in the airbox...
fuel - dodgy fuel pump, just plain out of fuel, throttle position sensor is faulty, dodgy injectors
spark - dodgy plugs, dodgy coil pack, duff ecu. dodgy crank position sensor.
EDIT now that I've posted something vaguely useful, time for something wholely not useful - why is this in the car care forum discounts area?
Edited by brillomaster
He couldn't check it deeply as he's quite busy so but I'm want to get it done as soon as possible as this is quite frustrating to be honest. I've replaced the air intake, i have it for a month and half already, when this happens i pull the accelerator to the bottom, the car don't have the power it should be but i can hear the induction filter but when the car works fine, i can't hear it, only on high Rev's don't know if this helps, by the way the way is an japspeed induction kit, it's not very good definitely but i gave it a try.
you have left the MAF sensor plugged in right? I've seen some of those kits where the MAF gets removed.
Yes it is plugged in.
when you installed it did you touch the butterfly valve of the throttle?
I think not, but not sure right now
Well made a mistake but cheers for the info
May be your using the wrong type of polish or wax on your body work ! ;):lol:
Lol ðŸ˜
