Help with warning light please
I have a warning light showing which I can not find in the manual. It is a yellow one, and looks like a horse shoe with a flat slightly jagged bottom, and a warning exclamation mark inside. It is at the bottom of the cluster of lights that come on when the engine is started, and stays on when the rest go out.
Any ideas ?
Tyres seem fine, so I assume it is a slight lose of pressure in one. Does the warning system identify which one is low ? Nothing in the manual that I can find.
Thanks for your help.
I think..... it shows when there is a measurable differential of pressure from 1 minute to the next (times are guestimates) - I don't "think" it shows if it goes down slowly
thought it was standard - but mine is the GT Edition, so there weren't any extras available
and its definately on that
when you next change your rubbers - its a little grey box fixed next to the air adder thingy :thumbs:
Just check the pressures in all 4 and inflate to correct pressure.
Report back if this does not fix your issue.
Problem solved. Pressure was down in all four tyres. :scare: Thanks for the help, and I think Nissan should up date their manual. Mine is dated 2010.
