Car broke down this evening - What is wrong ? ++ Now with PID CODES++
Posted (edited)
Evening All
Decided to take the Zed on a run today - First proper one of the year. Needed a few bits for the house so thought I would drive the 2 odd hours to Ikea Nottingham. Fuelled up (Momentum) just after picking the car up and headed to Nottingham. No problems, even did the brake bedding in which cured the steering shudder. Parked up at Ikea got the bits and left about an hour later. My App radio was playing up so at a Red light in Grantham turned the ignition off and restarted as this has worked in the past. Car refused to restart. Was turning over but not catching. Thought may leave it but conscious that the battery on mine even newish isn't the best so called the RAC out.
They were out in like 5 minutes. (impressed!) We both thought take the air filter off the pop charger see if it goes. He sprayed some ether up the induction pipe and started first time. Put the filter back on did the paperwork and headed off nervously for the last 60 odd miles to Kings Lynn. Up until the stop, no problems, no lights and no loss of performance. On the way back I now noticed the engine light was on as also the VDC off and SLIP warning lights. I tried to switch the VDC but could not get the light to go out. When I got home tried to restart and same problem wouldn't fire.
OK the only thing I have changed (last week) was fitting a plastic snorkel that fits to the heat shield, the car has been up revved but would that make a difference to the chip/fuel air mix ?
Also whats the link with the VDC/SLIP lights and the car not starting. I will try to get a code reader tomorrow and see what it says but a bit lost. The car has been supremely reliable for the year I have owned it so wonder if anyone else has a similar experience . Like i said on the way back it was fine no loss of performance but I don't think the VDC was off either
Rob
Edited by Mudman
I had slip and warning lights come on and wouldnt start before, was the cam shaft sensor (or crank shaft sensor). Picked up a replacement from Eurocarparts for around £50-60. Did a search and it says there was a recall for 03-06 cars. Code reader will be your friend though.
OK have the codes
Looks like its the cam sensor so any comments please - Car would not start today although now have some cold start. I do have a Nissan garage nearby but would prefer one of the traders to work on this. I am fairly confident I can nurse it a bit further unless limp mode is telling me not to
Is it worth clearing the codes as well before trying that ? I guess if the problem remains they will just pop up again.
Hi Mudman, see my post above, had the same P0340 code on mine.
Got to worth a try as Hammerz's issue does sound very, very similar, if not the same :thumbs:
OK probably have to wait until the weekends as will be dark when I get back. TBH I have a few things that need doing so might just take it to a garage. Just out of interest I called my local Nissan garage. Ran the problem past them, They claim its probably a stretched timing belt chain so that's a first. Also said they would be happy to run a diagnostic at £96.00 Told them that I already had done that and had the codes and would that then tell you if it was a timing belt as I dont think theres a code for a streched timing belt ? . Then started to question me as to when the car was serviced last. Doesn't really fill you with confidence does it, pretty much dismissed the Cam sensor saying its mechanical not electrical.
Rob, forget about the garages, specially Nissan ones! Just do what we've advised above to save yourself a lot of money. I'm pretty sure it's just the cam sensor. 30-45min job to change that sensor, see the video I've posted above.
Yep that's the plan but certainly won't be going anywhere near Nissan ! More updates after the weekend and will give this a go
Yes please - my main issue is time - if it was summer no problems I could do it it one evening but weekends are pretty much committed with having kids etc so they wont fancy Dad swearing at the clips on the car ! I also need a few other things done so quite happy to cough up this time so the cars ready for the Shelsey Walsh meet 4/3
Give Joe Graver TA Jeff Sutton Mechanics Wellesley Street, King's Lynn, Norfolk, PE30 1QD
01553 765224 a call.
He is not a 350Z specialist, but a dam good mechanic and really knows his stuff, and knows Japanese cars, and wont mess you about.
Just tell him Dick from across the road recommended him.
I also sent EzyGiz here to him and he was very pleased with the service,
http://www.350z-uk.com/topic/93900-recommended-garage-for-a-350z-in-kings-lynn/
Posted (edited)
Sweet will give him a call - been after a decent local mechanic for ages as the traders are all far far away and I have no leave left for the year already !
Edited by Mudman
By a sheer twist of fate had to work from home today so during my lunch hour replaced the cam sensor and she started first time :teeth:
literally took 15 minutes and 10 of those was trying to get the old sensor out - what is it with Nissan and harness plugs ?
Just for the record this was the successful technique
1. Slide the clip forward as far as it can go
2. Get a terminal or smallish flat head screwdriver and place in the slot in the middle of the green harness
3. Wedge screwdriver up against engine bay and pull back on harness carefully not using the wires
4. Sensor slides out easily
Many thanks to all that helped - Cars going in tomorrow for diff/oil/gear/coolant change and finally the red Mishimoto hoses
  • Like 3
See, I told you it was an easy fix, not worth paying for it :)
Glad to hear all went well and it wasn't anything else major.
Glad you got it sorted, Nissan gave me the wrong cam sensor (eventhough i told them it was bank 1 sensor) and then even with the right sensor it took me an age to get the old one unclipped so you did well with 10 minutes!
  • 1 month later...
OK have the codes
Hi Mudman,
This is probably going to sound so thick but, how did you get the codes to show on your phone? Is there an App that allows us to carry out diagnostic checks?
Thanks
Neil
Hi Neil
you need a ELM27 code reader off ebay for about a fiver that you pop into the scart like socket (OBDII) then pair with an app. There are many that do this so have a hunt. If you have a JDM then you are a little more restricted on choice than a UK model as I have only found 2 that are compatible with the JDM and you need a BT ELM rather than a WIFI one. I think you can use the dashboard app with WiFi ELM on the UK machines
Like this - (WiFi version)
http://www.ebay.co.uk/itm/WiFi-Android-iOS-Car-OBD-OBD2-Engine-Fault-Code-Tester-For-Apple-iPhone-Galaxy/221718071165?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140122125356%26meid%3D130ca3c42d5145f8b5ce3f772d6599a5%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D221457367188&rt=nc
If you go on the app store/android and search OBDII you can see what's available and once you have an ELM reader you can try before you buy to make sure they work
There are a few good threads on the subject on the forum so have a dig - I'm no specialist just got lucky finding something that worked for me!
