Still not starting
marko119
HI
FURTHER UPDATE ON POST LAST WEEK,WAS GETTING THE P0340 CODE ON MY 03 Z350 SO CHANGED BOTH CAMSHAFT SENSORS,BANK ONE WAS CHANGED TODAY IN A TYRE AND AUTOSHOP WERE I WORK BY THE MECHANIC,DUE TO A MIX UP BY LOCAL CARPARTS FIRM,THEY SUPPLIED ME WITH BANK 2 FIRST AND ON FIRST TEST DRIVE ALL LIGHTS CAME ON,BUT WHEN BANK 1 EVENTUALLY ARRIVED TODAY,ONCE FITTED ALL LIGHTS HAVE STAYED OFF AND UNDER TEST ALL FAULTS HAVE CLEARED AND ALL SEEMED TO BE GOOD.
CAR SAT FOR ABOUT AN HOUR TILL I WAS GOING HOME AND IT WAS A REAL PIG TO START,KEPT TURNING OVER BUT EVENTUALLY FIRED UP,DROVE IT HOME LIKE A MADMAN AND TURNED IT OFF IN DRIVEWAY,TRIED STARTING IT AGAIN BUT SAME THING,REALLY HARD TO FIRE UP.
HAVE BOOKED IT INTO A DIAGNOSTIC COMPANY ON MONDAY IF IT STARTS TO GET ME THERE,BUT HAS ANYBODY ANY IDEA WHAT COULD BE THE PROB IN THE MEANTIME,CAR HAS NEVER GAVE ME ANY TROUBLE IN 8 YEARS
ORIGINAL CODE ON OUR DIAGNOSTIC MACHINE AT WORK WAS CAMSHAFT SENSOR BANK 1 P0340..
Is your 350 a JDM? I only ask as UK and JDM sensors may be different - had an issue with a crank sensor in mine JDM one caused problems in a UK car but was fine in the JDM we borrowed it from :shrug: - next thing to try is the crank sensor CPS between it and bank one cam sensor the timing is worked out. or so I believe.
Since my last update heres whats happened,since replacing the 2 camshaft sensors,car was hard to turn over.Took it too my mates garage who ran a full diagnostic test by Snap on and was reading bad signal from the 2 Intermotor sensors,said they were of not a good quality and got replaced by genuine one plus a new crankshaft sensor.Said all is scopeing back a 100% so when i lifted it tonight the car turned over ok cold,but once i drove it home and tried starting it again it took for ages to fire up,
The car drove without a misfire or problem and no lights on the dash,but not starting without alot of turning,he is stumped now too as he has got alot of info this week and feed back from Snap on,but to no avail,and he is a personal friend and not ripping me off with cost.
Can anyone help with this matter now or is it a Nissan job
He has just came and lifted the car,started first time but he stalled it reversing it out,then it started the turning over without starting lark :) so i think hes gonna check all other aspects now as the P0340 has been leading him astray a bit,could be a coincidence that something else has happened at same time as sensors,meanwhile am back to driving a VW Crafter van :)
