Hi all
Quick question regarding my clutch. The pedal has recently been a lot higher than before, but no clutch slip or judder whatsoever. I've done the low speed/high gear tests etc and it is fine.
Has anyone with a HR had a similar issue before their clutch failing/slipping? Is it something to worry about as I am aware a new clutch/flywheel etc is pricey on a HR 350z.
Thanks in advance
If the clutch isn't slipping or dropping to the floor then there is nothing to worry about just now. There is DEs getting close to 100K on the original clutch :thumbs:
Yeah I've had a quote for the clutch fitted for £950 but that's not including flywheel which are ridiculously priced!
Road trip planned for mid march.... Sod's law will go then!
My clutch pedal stuck to the floor constantly during a track day at Castle Combe in August last year, after so many laps it would just boil up and stay grounded. I would pull into the paddock and wait for it to cool down and return to normal. I am assuming it was old fluid, replaced it with some rf600 so hopefully it won't happen next time.
If their genuine a right bargain so might be worth contacting them for your model
http://www.ebay.co.u...tem3cf1668011��
and if your concerned about LUK
http://motorequipmen...ls-invented-luk
If the make of the clutch is unknown then ask them for a branded one with the LUK DMF
The eBay listing posted is for a DE and not HR
Thats why i said contact them for your model :p
Not sure what zman will charge you so might be best to ask there first
Edited by gsexr
I went to overtake a car and had my foot down hard and the clutch pedal fell to the floor and there was a burnt coffee smell. but after about 50 seconds it went back to normal. It happened to me a few times when going to overtake hard so got almost all my money back from the dealer I bought it from.
Regards Keith B)
