Mudman Posted July 24, 2014 Posted July 24, 2014 Gday All Got some of this in red and presumed you removed the original (black) and replaced but seems a bit thin so better option might be just over the top as its split conduit - that the norm ? Quote
mattross1313 Posted July 24, 2014 Posted July 24, 2014 yep, myself and Ian both wrapped around the existing black loom. Quote
14N Posted July 24, 2014 Posted July 24, 2014 (edited) Yep, what Matt said Be prepared for sore fingers In before the lock Edited July 24, 2014 by 14N 1 Quote
Payco Posted July 24, 2014 Posted July 24, 2014 I have done the same, bit of a fiddle in some areas.. Good luck. Quote
RDON Posted July 24, 2014 Posted July 24, 2014 where can you get the non sticky pvc tape from that they wrap the wiring looms and ends of the conduit from. I need some in blue but struggling to find some where? Quote
jimmy.farrow7 Posted July 25, 2014 Posted July 25, 2014 Ebay mate I brought a set of conduit and the tape, I will try and remember later and I will send you the item number Quote
Payco Posted July 25, 2014 Posted July 25, 2014 i used cable ties strategically placed... Didnt need tape.. Quote
gumpy000 Posted January 16, 2015 Posted January 16, 2015 Ok help me then. What size conduit do I need for under my De bay? Iv done some of the smaller pipes but for the ones that already have black conduit. What size is that? Many thank you's. Quote
firemansim Posted January 17, 2015 Posted January 17, 2015 Just order a kit from E-bay, it comes in lots of different sizes. Quote
Payco Posted January 18, 2015 Posted January 18, 2015 (edited) As per Firemansim.. Edited January 18, 2015 by Payco Quote
14N Posted January 18, 2015 Posted January 18, 2015 As above, the kit comes with different diameter sizes. You just need a little forward thinking to figure out which you're gonna use where. Quote
