350 Russ Posted June 12, 2014 Posted June 12, 2014 (edited) Is it worth it or should I just change a few of them? hard to do? worth it in the long run. Car is just used on road and not tracked, with all other standard suspension othe than being braced with the GT spec bracing kit. Time to fit isn't an option as it will be off road for about a year, so plenty of time to get the work done. Edited June 12, 2014 by 350 Russ Quote
Jp606 Posted June 12, 2014 Posted June 12, 2014 (edited) For the same price as a full set of bushes (nearly £1k) or a little bit more, I'd spend the money on suspension tweaks, ARBs, lowering/stiffer springs or coilovers and a good alignment. The improvement in handling from those will far exceed bushes, I'd say the bushes are more to compliment other handling tweaks. I believe Jez from H Dev has a set on his car, but I think it was because he tracks it, there is a thread somewhere. I'd only go for front bushes for the upper and lower control arms, compression arms and ARBs if you only want to do them. As for changing them, you need a press to remove and reinsert the new ones (excluding ARBs), so either remove the arms and pay a garage to do them or buy a press.. Also important to get an alignment afterwards. Edit - here http://www.350z-uk.com/topic/48020-superpro-bushes/ Edited June 12, 2014 by Jp606 Quote
Tarmac@TarmacSportz Posted June 12, 2014 Posted June 12, 2014 One of these sets would make a nice difference: http://www.350z-uk.com/topic/85095-whitelines-awesome-nissan-350z-bushing-essentials-kit-220/page__hl__whiteline Quote
djtimo Posted June 12, 2014 Posted June 12, 2014 Mega work for minimal gain if you OEM every where else IMO. Ive just done full front poly kit and the car does feel better but Im on KW V3's with roll bars etc.. Quote
Jp606 Posted June 13, 2014 Posted June 13, 2014 One of these sets would make a nice difference: http://www.350z-uk.com/topic/85095-whitelines-awesome-nissan-350z-bushing-essentials-kit-220/page__hl__whiteline Are the Whiteline bushes align adjustable like SuperPros? Camber on the upper arm and castor on the compression arms? Quote
jakno1 Posted June 15, 2014 Posted June 15, 2014 Iv just finished a full master set from energy suspension, worth it if you can be bothered its very labour intensive, there is a big improvement in handling and feel its must more stable and responsive. Quote
CurtisZ Posted July 6, 2014 Posted July 6, 2014 Just did the full set of front poly bushes on mine! I would say a MUST ... 'For the same price as a full set of bushes (nearly £1k)' .... ehhh £126 from the USA for Upper & Lower Control Arm Bushes with the Compression/Banana Arm Bush too http://www.350z-uk.com/topic/87055-front-bushes-prothane-from-usa/ Suspension feels slightly stiffer and the car in general is so so so much more responsive Quote
