wiper jets dont work
Dashurik
One of my windscreen jets don't work.Others are fine,all spraying well.I tried to unblock jet holes with needle,but i didn't help!! I believe it blocked elsewhere or may be worse:something need replacing!Can anybody guide me where to look and what to look for?
It may be that the small rubber pipe that connects to the washer arm has popped off? I'd start by checking at the wiper arm end and then following it along it to see if it has come off anywhere else. Good luck. :)
Try replacing the non return valve. Costs about £2 and is a common cause of washer jet issues.
It's found tucked up under the brake fluid cover just below the windscreen.
