its called a 'b-pillar'. That should help you find instructions.
Its the first thing I wrapped, remember to peel off the two rubber edges before wrapping and glue them back on after. I think I had to cut mine off.
Off now guys! Thanks!
Randy I've removed them to wrap them and was planning on wrapping the rubber seals as well. Is this not adviseable? And would it hurt just removing them completely? Do they serve much of a purpose?
Sent from my GT-I9300 using Tapatalk
I think they stop water getting in behind the b-pillar, I just glued mine back on with super glue. Apply a hair dryer to them and they should come off pretty easily.
I also clear coated my wrap to make the carbon look a bit shiny. I wrapped a ruler and laid down masking tape a regular intervals to see how many layers of clear coat was best, think I went for 3.
Removing them completely is a definite no no ... I'd polish them up or get them sprayed
mine after polishing
I wrapped mine and if you are very careful you can tuck the wrap behind the rubber. Trim it off with scissors leaving about 3mm excess and then tuck it behind with a plastic spreader or similar.
