TiN TiN Posted February 11, 2014 Posted February 11, 2014 Have been reading that it's common for LSDs to get messed up if the car's been a MOT rolling road for the handbrake test. How can you tell if it's messed up? Quote
Robothobo Posted February 11, 2014 Posted February 11, 2014 Is it the brown LSD? That's bad apparently. Sorry. Couldn't resist. Quote
TiN TiN Posted February 11, 2014 Author Posted February 11, 2014 Didn't realise we had comedians on the forum :-/ Quote
brillomaster Posted February 11, 2014 Posted February 11, 2014 Do some donuts with some attractive girls watching. If they walk away in disgust at your feeble single tyre smoking, your LSD is lunched. If, however, all of their clothes instantly fall off at your super mad drifting skillz, you've got a fully functioning LSD. 4 Quote
AliveBoy Posted February 11, 2014 Posted February 11, 2014 Jack up the back end, and spin one wheel. If the other spins the same way, you have a LSD. If it spins the other way, you have an open diff or a broken lsd. Or, pull up on a quiet secluded road and drop the clutch, if you leave 11's you have a fully functioning LSD, if you leave a 1 you haven't 1 Quote
Scootg Posted February 11, 2014 Posted February 11, 2014 I love that, if you leave a 1. Hehe. Sound advice though. Sent from my iPhone 5S using Tapatalk Pro. Quote
peteman35 Posted February 11, 2014 Posted February 11, 2014 (edited) Sorry for hijack but does any one else get tyre hop? very annoying Edited February 11, 2014 by peteman35 Quote
GT4 Zed Posted February 11, 2014 Posted February 11, 2014 Have been reading that it's common for LSDs to get messed up if the car's been a MOT rolling road for the handbrake test. How can you tell if it's messed up? That's BS. The LSD should get any issues from an MOT test or multiple dyno power runs either. The oem VLSD is a life long item. As expected it will become weaker in its locking overtime due to wear and tear and deterioration in the viscous oil but that's it. In the unlikely event your diff has packed up for one reason or the other the described tests above will tell you if its performing or not. If its knackered then its you chance to get a Quaife or clutch type diff and be amazed at what you were missing😎 Quote
GT4 Zed Posted February 11, 2014 Posted February 11, 2014 Sorry for hijack but does any one else get tyre hop? very annoying Yep all OEM cars suffer with this due to mushy subframe and diff bushes primarily. Replace all the rear bushes with urethane or solid mono ball bushes and you will get rid. Cost a lot in labour but worth it if handling and full power delivery is you main goal. 1 Quote
Ewen@Clark Motorsport Posted February 11, 2014 Posted February 11, 2014 Sorry for hijack but does any one else get tyre hop? very annoying We sell the Whiteline rear diff bush kits that will improve things although they do make it stiffer for ever day road use http://www.350z-uk.com/topic/78338-whiteline-rear-diff-bush-kits-for-350z-7499/ Quote
peteman35 Posted February 11, 2014 Posted February 11, 2014 Sorry for hijack but does any one else get tyre hop? very annoying We sell the Whiteline rear diff bush kits that will improve things although they do make it stiffer for ever day road use http://www.350z-uk.c...-for-350z-7499/ Do these fit the same as Alex describes I guess the ones he has are whiteline as they are yellow. http://www.350z-uk.com/topic/64571-350z-poly-bush-kit-for-differential/ Quote
Ewen@Clark Motorsport Posted February 11, 2014 Posted February 11, 2014 Yes in the same way, they are exactly the same bushes just now made in black material not yellow. Whiteline also reduced the price at the end of last year We have them in stock Quote
:RedZed: Posted February 11, 2014 Posted February 11, 2014 Yes in the same way, they are exactly the same bushes just now made in black material not yellow. Whiteline also reduced the price at the end of last year We have them in stock I got some of these from Clark Motorsport because my OEM items were identified as causing the 'bump' i was getting when changing gear quickly during 'fruity' acceleration. They did the trick and there is a positive overall improvement which I find it hard to describe. General driving just feels tighter is about the best I can manage. Oddly the exhaust note sounds slightly better inside the cabin but I'm not sure how that's possible, perhaps someone can explain? I should add, these are apparently a bitch to fit. I got mine fitted at TGM in Fleet and was told it was a horrible job. Glad I didn't attempt it on the drive!! Quote
