is it possible to upgrade a 2009 HU with a 2010 system?
Hey
I've seen a 2009 370 which i like but am i right in thinking it doesnt have the connect plus system? which has iPod and postcode gps?
can i upgrade my 2009 system to a 2010 and also add a reverse light camera?
thanks in advance
I haven't seen the upgrade done but I can't see why not, how easy it would be is unknown, checkout 370z.com, maybe someone has done it there
You can fit a reverse cam to either unit but they are fitted/wired differently
Still though £190 is a lot of money. I would rather get a complete aftermarket with a better amp built in like alpine. But I've heard that the connect system is integral to the car so can't really be removed?! :s
Is the same one in the micra?! Blimey! Lol
Okay. Silly qu again but the Americans all seem to be changing their head units for aftermarket ones. I thought we couldn't change the HU since everything is linked to it??
When people change the HU do they all need to change the speakers too?
Thanks
  • 4 weeks later...
Thanks
I am getting this done next week. If you have the NAV then its pretty hard as its all linked in.
I either wanted connect premium or none Nav model so I could add my own in.
I saved a good 2K over a 2010 model so using half of that for a decent double DIN :)
  • 4 weeks later...
I believe if you have the standard and move I a 2010 connect premium then you also need to change the ECU and maybe other components.
Someone tried and left it at that once they found it out.
Better off going after market as mentioned.
