Hey all,
I recently did a thread about my exhaust rattling between 1000-2000rpm.
After checking all bolts, heat shields and if anything is touching (up to the end of the HFC cats), I'm not 100% if it is the exhaust. Therefore I have started a new thread but provided more info.
Noise: VERY loud metal - metal rattling/vibration
When: between 1000-1750 rpm
Gears: all forward gears
Stationary: doesn't happen with clutch in or out
Mods: Y pipe without flexi, lightweight flywheel clutch, berks HFC's.
I've checked the exhaust system and can't see anything touching or loose (up to end of cats)
I have read similar threads but most seem to be exhaust related. Numerous people have mentioned the y pipe without flexi's but many people have these and don't experience the same problem.
Hopefully this has given a better idea of the situation and may have been experienced by others.
Thanks in advance
That's the lightened flywheel causing that. It's normal for a lightweight flywheels to do this. It's like a metal chatter
Really?
It sounds absolutely terrible and can be heard from miles away :embarrassing:
It's not quiet at all lol
