window motor sticking
Aikido2856
This is a long shot. Is it worth trying the window reset procedure before doing anything else?
1. Make sure the window is shut.
2. Keep the window button pressed down for 15 seconds. (The window will open)
3. Hold the window button in the 'up' position for 15 seconds. (The window will close)
Probably won't solve your problem, but it's worth a minute of your life, just in case.
I have the same issue and need to buy a new motor for my Import 350z Fairlady anyone know where I can get one from apart from Nissan :(
have you tried the guide above first and refurbish the motor otherwise traders on here that sell them are Clarks Motorsport or Horsham Developments
