Pads and Rotor- advice needed :)
Hi All,
Z's going in tuesday to check pads n rotors all round, almost sure i will need rotors(discs) as they have been on the car for almost 9 years and dont feel as sharp as they should be :blush:
had a search on here, which in turn gives loads of different options and opinions, can anyone recommend pads and rotors that wont break the bank but still a slight step up from OEM perhaps ?
no track days, just spirited driving when the conditions allow :drive1
Thanks in advance :)
Posted (edited)
Black Diamond discs and the matching Predator pads. Replaced my OEMs with these and they are a brilliant step up for relatively little money, perfect for fast road use and they look cool too :)
CS will sort you out.
Edited by Jp606
Just priced up some black diamond dics n pads all round, Just over £400 on average, so thats 2 votes for black diamond, anyone else ?
Just got back from the garage, checked all the brake discs n pads everything seems fine with plenty of 'meat' left on them, they cleaned up the brakes and reseated the pads,seem a lot better now.
Also had the brake fluid changed as i cant remember when that was last done :blush:
If i'm still not happy then i'll look at the options in here from our various traders :teeth:
