modd1uk Posted September 13, 2013 Posted September 13, 2013 Ok guys, with winter coming i need to get this sorted as the recent few days of rain have made my car smell a little . Picture below of passenger footwell, does anybody have any idea where its coming from/how to fix it, its coming from the panel under the door from what i can tell if that helps. Quote
Will370z Posted September 13, 2013 Posted September 13, 2013 I had the same problem with my roadster. Water was coming in from the top of the passenger window, following the contour of the window to the front of the door, travelling down the edge of the door at which pointit should have been funnelled towards the outside of the door but for me it came inside instead. My fix was to open the door, get thick pieces of tape and near the vent stick the tape at an angle to filter the water stream out of the car. It improved the problem but ultimately did not resolve it during heavy rain. Its oneof the reasons i eventually sold the car. Quote
Keyser Posted September 13, 2013 Posted September 13, 2013 I had this really bad - I did a window reset - my passenger window wasn't doing up tight enough - fixed it for me she has been dry ever since 1 Quote
Richie-B Posted September 13, 2013 Posted September 13, 2013 Edd china hired a smoke machine and filled the inside of the car with dry smoke.. then the leak was found by looking for smoke coming out. Worth a try if your struggling. Quote
modd1uk Posted September 13, 2013 Author Posted September 13, 2013 Window reset. Care to elaborate keyser? Quote
Pnthrblkzs Posted September 13, 2013 Posted September 13, 2013 http://www.350z-tech.com/wiki/index.php?title=TSB_04-089_Window_Regulator_Motor_Reset_Procedure Quote
HaydnH Posted September 13, 2013 Posted September 13, 2013 I had the same problem, then I started driving a little slower when I had a passenger and the problem went away. 2 Quote
ioneabee Posted September 13, 2013 Posted September 13, 2013 different kind of smell Haydn !!!! Quote
M13KYF Posted September 13, 2013 Posted September 13, 2013 other thing to check is the windscreen surround. Thin k there has been a coupl eof members who have had that as an issue Quote
