Annoying rattle from the speedo
A rattle, if I put my hand down the back and push against the clocks it stops.
Anyone know how to get the clocks out so I can see if anythings loose?
Do a search, topic has been disgusted before. ;) It's also possible it's not your speedo, but the window rubbing on the dash. Hone in on the noise, if it is, easy fix, get some more high density foam, squeeze it in.
