Dual pop charger on Hr
downhuman
How bad is the heat soak?
Over exaggerated and an over used phrase on here if you ask me but I would say that as I sell intakes. ;)
I'm sure Mark will have a more experienced answer from a tuners point of view but a naturally aspirated car in this country that's used for commuting and a bit of spirited driving now again will not suffer terribly. Yeah if your stuck in a traffic jam on a boiling hot day then you might suffer a bit until you start moving but that's the case with most cars any how.
I think it is bad, just sitting in traffic I have recorded 60+ deg C inlet charge, even if the AFM ( which houses the IAT ( air inlet temp) cools quickly the alloy pipework takes longer to cool. Plasticstock airbox/pipework works fine seen over 325 hub bhp on a 370Z running stock airboxes.
