NEWBEE QUESTION........... 2nd gear ?
JEMAN
Hi all,
Ive had my Z for a couple of months now, and really enjoying it :) Its a 2003 with 42k on the clock, full Nissan service history. My question is that second gear makes a slight crunch when cold every now and then...........is this normal ? All other gear changes are OK
1st to second has always been a bit of an issue with the zed.
Ive found after the car warms up it gets a little leff stiff. If its falling out of gear, id get it checked out, but if its just a bit of a tough pull or a few attempts at getting it in, its just due to the car not being warm enough.
*Also if you drop it down a gear from high revs it tends to not like it aswell.
i personally thought it was not the cold but a common fault in zed gearboxes with the syncros wearing out??
It's both really, the synchros on early gearboxes simply aren't up to the task and can cause crunches, particularly in 2nd 3rd and 5th. The cold tends to highlight the problem because nothing works as well with cold fluid.
DB
