aterro Posted August 23, 2012 Posted August 23, 2012 Just did a mot check and came back with this in 2012! This is on a import car 2004 year old. Nearside center chassis Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2) Offside center chassis Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2) Advisory Notice issued Leaking pas fluid Steering rack damaged but serviceable (2.2.C.1d) This a bad sign already? (this mot was passed at the same place where they did failures and advisories) Advisory wasnt fixed... what could this be? and the rust sounds awful? Where would this be? thanks Quote
aterro Posted August 23, 2012 Author Posted August 23, 2012 just been told it was Underside near seats was rewelded with new panels, and all undercoated and resprayed? steering rack isnt damaged and its a easy job of a rubber washer? then he gave me garage phone number for proof- Was done at ford... Quote
The Chubby Ninja Posted August 23, 2012 Posted August 23, 2012 I would give the garage a phone and see if they can comfirm the works been done. I think your ment to underseal it when it was imported, well ive had 2 imports and got them undersealed when i imporeted them. Its maybe not been done in this case. My 350 is an 2004 uk car and its pretty rusty underneath too. The british roads are crap and the salt just eats away on the underneath of the car Quote
aterro Posted August 23, 2012 Author Posted August 23, 2012 its a 2004, cannot believe how rusty it got for that work to needed to be done? ill ring the garage and ask what it had done. Quote
Vik54 Posted August 23, 2012 Posted August 23, 2012 Imports should be undersealed if they've been brought in by a decent company. I'd leave it if I were you - find another one Quote
marzman Posted August 23, 2012 Posted August 23, 2012 How did you do a check on previous MOT's? Quote
ewan221 Posted August 23, 2012 Posted August 23, 2012 How did you do a check on previous MOT's? http://www.direct.gov.uk/en/Motoring/Ow ... G_10020539 Quote
leonk Posted August 23, 2012 Posted August 23, 2012 As Ewan says Chris, but you'll need either the current M.O.T reference number or the V5 reference number. Quite interesting as they now list the fails and advisories online so great info if you are looking to buy a car. Quote
marzman Posted August 23, 2012 Posted August 23, 2012 Brilliant - never knew about that! I might have a dig through my 'cars' folder and see if i've got some old docs that i can do some searches with. Quote
