Arghhhhhhh, squeeling noise
Rscut
Afternoon,
I picked up my zed on Saturday and noticed a noise from the back end when accelerating and breaking. It seems to make the noise also when i move the car from side to side. It sounds like something is squeaking as it moves backwards and forwards, almost like something is loose.
When i text the previous owner he said it needs 10mm off the center pipe. So i took it to the garage today and he had a look around the exhaust, tighted things up, took the hanger off the back support and the noise is still there! The mechanic reckons it might be a dodgy spring in the rear brake drum but i dont see how it can be?
Anyone got any suggestions?
Could be sway bar drop links or sway bar bushes:thumbs:
Disconnect them and take the car for a spin, if the noise has gone then you will know that you are on the money.
All in stock and good to go same/next day if required. :thumbs:
Alex. :)
When we put the handbreak on and rocked the car on the clutch In 1st you could here it. Almost like it was moving and the squeal was from a lack on lubrication. I'm finding it hard to describe to be honest! Just peed off it started doing it on the way home and not when I test drive it!
Get the car on a ramp and replicate the rocking procedure, watching not to drive off the raised ramp as the hand brakes on the zed are not the best :scare:
Give all the rear bushes etc a good spray with a suitable penetrating lubricant whilst on the ramp.
Alex. :)
