Rscut Posted February 6, 2012 Posted February 6, 2012 Afternoon, I picked up my zed on Saturday and noticed a noise from the back end when accelerating and breaking. It seems to make the noise also when i move the car from side to side. It sounds like something is squeaking as it moves backwards and forwards, almost like something is loose. When i text the previous owner he said it needs 10mm off the center pipe. So i took it to the garage today and he had a look around the exhaust, tighted things up, took the hanger off the back support and the noise is still there! The mechanic reckons it might be a dodgy spring in the rear brake drum but i dont see how it can be? Anyone got any suggestions? Quote
EH 370z Posted February 6, 2012 Posted February 6, 2012 Brake "Drum"? The car needs a look at I think by a tech that knows a drum from a disc brake. Sounds like a suspension bush Quote
JetSet Posted February 6, 2012 Posted February 6, 2012 I thought the handbrake was operated by a small drum at the rear? Pete Quote
ZMANALEX Posted February 6, 2012 Posted February 6, 2012 Could be sway bar drop links or sway bar bushes:thumbs: Disconnect them and take the car for a spin, if the noise has gone then you will know that you are on the money. All in stock and good to go same/next day if required. Alex. Quote
Rscut Posted February 6, 2012 Author Posted February 6, 2012 When we put the handbreak on and rocked the car on the clutch In 1st you could here it. Almost like it was moving and the squeal was from a lack on lubrication. I'm finding it hard to describe to be honest! Just peed off it started doing it on the way home and not when I test drive it! Quote
ZMANALEX Posted February 6, 2012 Posted February 6, 2012 When we put the handbreak on and rocked the car on the clutch In 1st you could here it. Almost like it was moving and the squeal was from a lack on lubrication. I'm finding it hard to describe to be honest! Just peed off it started doing it on the way home and not when I test drive it! Get the car on a ramp and replicate the rocking procedure, watching not to drive off the raised ramp as the hand brakes on the zed are not the best Give all the rear bushes etc a good spray with a suitable penetrating lubricant whilst on the ramp. Alex. Quote
