How to remove centre console??
In previous post I am having trouble with my heating - Does anyone actually know how to remove the console where the heater controlls are? Is it a case of getting a screwdriver behind it? Or are there some hidden clips etc? cant seem to see anything though :(
Thanks!!
And don't mess/bend/lookfunny/touchinappropriately/fondle the white ribbon cable if you get that far. Be very careful.
You were warned.
EDIT: I should clarify you'll need to disconnect it from te back o the temperature controls for better access but it's fragile so be really careful. If you try to pull the controls out too far before disconnecting it you could break it.
