tried to take off my boot struts today to send them off to sgs engineering to get them regassed. i got the bottom two botls out ok, but the ball joint on the top i couldn't budge.
Does the ball joint just pop out of the socket or do you have to wind out the entire fitting?
also i have a nismo v1 spoiler, does anyone know how much they weigh so they can gas them up to suit.
You need to un-bolt both ends. If you pull the ball joint out you'll have a tough time getting it back in, if at all?
Weight on the spoiler I can't help you on, try searching google :shrug:
If it's a stock one, lube it then twist it up the the max of it's arc movement and it should slip out ok. If it's after market look for the wire release clip.
They claim to know the weight of spoilers so should do you the right pressure strut.
  • 5 months later...
