stuarty Posted May 26, 2011 Posted May 26, 2011 When warm my 54 plate Zed ticks over at around 600 ish RPM and every now and again the car shudders slightly. I was told that this was ok Any advice please? Quote
Ekona Posted May 26, 2011 Posted May 26, 2011 600rpm seems a tad low but I don't think it's anything to worry about really. Anywhere between 600-800rpm is fine. Quote
Neilp Posted May 26, 2011 Posted May 26, 2011 Alright stuarty. After speaking with you the other day a thread cam up by someone else with regards to something similar but more extreme. They were getting popping/knocking etc. Usually about 700rpm is perfect, most people find running the air con helps smooth it out. Mines idles at around 800-900rpm due to the decats etc I think. Quote
coldel Posted May 26, 2011 Posted May 26, 2011 Sounds fine to me too...most cars I have owned sit below 1000rpm and occasionally the needle drops and it shudders a bit then comes back again, in effect just the auto choke type thing working I would have thought? Quote
scottyd Posted May 26, 2011 Posted May 26, 2011 Mine also sits around 600-650 and there's an occasional knocking and pop from the exhaust, I assumed it was normal? Putting the air con on sorts it out Quote
stuarty Posted May 26, 2011 Author Posted May 26, 2011 Mine also sits around 600-650 and there's an occasional knocking and pop from the exhaust, I assumed it was normal? Putting the air con on sorts it out Yeah mate, i get the odd wee pop from the exhaust as well. Aircon on does help. Quote
jan8p Posted May 28, 2011 Posted May 28, 2011 Surely a cause of the slight judder/needle wobble would be when the aircon compressor+fan kicks in which it will do every couple of minutes? Quote
Chris`I Posted May 28, 2011 Posted May 28, 2011 Leave aircon on all the time. It only kicks in when needed, but somehow manages to smooth out idle a lot. With it off, IMO it idles too low and almost stalls itself. Maybe some kind of imissions thing? Quote
Dblock Posted May 28, 2011 Posted May 28, 2011 Leave aircon on all the time. It only kicks in when needed, but somehow manages to smooth out idle a lot. With it off, IMO it idles too low and almost stalls itself. Maybe some kind of imissions thing? I found my car used to be like that until I cleaned the throttle body good and proper and did all the resets, now it seems fine. Quote
