Suspension bushes
Leeroy
I need a couple of new bushes on the front (need to check the car, pretty sure it's the usual compression arm bushes) and am thinking of replacing all suspension bushes front and rear as the car's done 65K.
I'll be getting them off the usual suspects on here, defo Alex' new press in banana arm bush. The easiest option is to use my trusted local garage, does anyone foresee any issues with a non Zed specialist doing it? I mean they're pretty standard items aren't they?
  • 1 month later...
When I change the banana arm bushes is it recommended to change any other front bushes at the same time? I'm assuming the only shot bushes are the banana arm ones that I know about, but is there anything to gain by doing others while the suspension's partly in bits anyway? If so which ones should I be looking at doing?
  • 1 month later...
A bit of an update, I finally got a chance to get the wheels off the car yesterday to inspect the bushes (ooh err missus!) and it's actually the bush on the transverse link where the suspension strut mounts to it that's split. It doesn't look any worse than it did for the MOT a few weeks ago but I want to change it soon.
Can anyone recommend a bush for this instead of a stock one? I don't want a harder ride though :thumbs:
Also, any ideas on a ball park garage cost for this?
Cheers :)
  • 5 months later...
Bit of a bump, I'm thinking about getting these transverse link bushes fitted soon, before geometry alignment. The suspension isn't knocking and feels fine - it was a minor advisory on the last MOT.
Can anyone recommend an aftermarket bush which gives beter handling with little ride compromise?
GO SUPERPRO!!!
I fitted the ARB bushes at the weekend and noticeably even in the wet an improvement, just gives you a little more stability. Also to fit are the SuperPro lower compression bushes which will fitted on Friday.
The quality difference from oem speaks volumes. They maybe expensive for what they are, but if they last and improve handling you can't go wrong :thumbs:
