Wasso Posted November 14, 2010 Posted November 14, 2010 Looking to replace the above..... Anyone have guides or tips? What are the required fluids to replace, or is it easier to get someone else to do it, cos I'm feeling a tad lazy today Quote
Ian Posted November 14, 2010 Posted November 14, 2010 Coolant is easy, can do that with minimal fluid loss. Power steering is a bit harder , imo its easier(cleaner) to drain it & then remove it. Remove both but fit the power steering first or you will have to remove the coolant tank again to fit it. Quote
Wasso Posted November 14, 2010 Author Posted November 14, 2010 Cheers Ian, thanks for the tips! Quote
P15UL T Posted November 14, 2010 Posted November 14, 2010 the powersteering gave me a bit of a headache, i should have drained it , but hey you learn from your mistakes Quote
Madmarky Posted November 15, 2010 Posted November 15, 2010 the powersteering gave me a bit of a headache, i should have drained it , but hey you learn from your mistakes I emptied mine with a turkey baster, then connected new one, topped up and job done Quote
Wasso Posted November 15, 2010 Author Posted November 15, 2010 the powersteering gave me a bit of a headache, i should have drained it , but hey you learn from your mistakes I emptied mine with a turkey baster, then connected new one, topped up and job done Looks like a job for next Sunday then. Just out of curiosity, should I be replacing the coolant and steering fluid to do the job properly?? The only doubt I have about this whole this is the bottles have no way of indicating max or low volumes. Therefore if I empty both systems how will I know how much fluid to replace with? There is the alternative of retaining the current fluids I guess? Quote
Madmarky Posted November 15, 2010 Posted November 15, 2010 the powersteering gave me a bit of a headache, i should have drained it , but hey you learn from your mistakes I emptied mine with a turkey baster, then connected new one, topped up and job done Looks like a job for next Sunday then. Just out of curiosity, should I be replacing the coolant and steering fluid to do the job properly?? The only doubt I have about this whole this is the bottles have no way of indicating max or low volumes. Therefore if I empty both systems how will I know how much fluid to replace with? There is the alternative of retaining the current fluids I guess? The coolant is just a overflow so wont have much in if any, but this is determined by the rest of the cars coolant system. In the powersteering bottle there should be a metal frame and the steering fluid should be just above that I think. Quote
dcash5 Posted November 15, 2010 Posted November 15, 2010 Personally i'd bleed the coolant just to be completely secure that not air got in. Plus its a fairly easy job. Powersteering fluid is ATF (auto transmittion fluid) that can be bought relatively cheaply from Nissan themselves. Dan Quote
