D4XNY Posted July 2, 2010 Posted July 2, 2010 Hi, I done a search, but didnt really find any solid answers so thought I would post up..... I basically need to feed some wire from the engine bay to the cockpit... I've read, and had a look but couldnt see much about a gromit behind the battery with an electric loom going through it......fair enough. To get to it though, I feel as though I have to remove the battery...... Will this bodge up my bose stereo? Will I then need a code, cos I dont have one... And I know about letting the windows down a few inches.... ha ha Any advice or knowledge, greatly appreciated Dan Quote
Ian Posted July 2, 2010 Posted July 2, 2010 No need to remove battery Just remove battery cover, remove rubber strips, remove poppers from surround & remove. gives you full access to the grommet Quote
alessandro Posted July 2, 2010 Posted July 2, 2010 Had my battery changed last March, nothing was needed, plug and play Quote
Husky Posted July 2, 2010 Posted July 2, 2010 you should definately be disconnecting the battery before doing any electrical work on the car anyway bud Quote
Ian Posted July 2, 2010 Posted July 2, 2010 you should definately be disconnecting the battery before doing any electrical work on the car anyway bud I learnt this the hard way £18 for a bloody ignition fuse Quote
D4XNY Posted July 2, 2010 Author Posted July 2, 2010 ha ha, good advice lads... Yeah I always disconnect battery when doing electrical work Im just worried about the stereo thats all Besides, looks like I wont need to remove the battery to get to the grommit now anyway, thank god! Quote
Chris`I Posted July 3, 2010 Posted July 3, 2010 No need to remove the battery mate. Take off the battery cover, then there are 5 or so plastic pop rivets (like those that hold on all the trim/bumber/etc). This will allow you to remove the plastic covers that make up the bit that the battery cover goes into. It spans from just in front of the battery cover, back to the window and across about halfway of the window. As Ian says, remove the rubber strips and you will see. This should help (its for US cars so reverse the sides that you do stuff on ) - http://liljerk.morpheus.net/350Z/firewall/ Quote
pathfinder123 Posted July 3, 2010 Posted July 3, 2010 No need to remove the battery, but it's always a good idea to disconnect when doing any electrical work. Always disconnect the battery negative lead first, that way if the spanner touches between the positive terminal and the car metalwork there is no short circuit of the battery. When reconnecting, connect the positive lead first. S. Quote
jhnharvy773 Posted March 26, 2011 Posted March 26, 2011 I just did the champion double platinum plugs and the magnecor wires. Should I disconnect the battery to reset the computer and for how long? Just thinking on this the other day because I would guess it would spark different than original plugs. _______________________ "Too much is never enough" Quote
