not going well - help needed!!
I'm half way through replacing the pads on the rears (this is a JDM non brembo setup), I have opened the calliper and removed one side of the pads but cannot remove the other side even a millimetre.
I have been following this guide - viewtopic.php?f=35&t=16773
I have removed the visiable pad from this picture;
am I missing something really stupid here?
I tried wd40 and brute force but the other pad just will not budge - I'm out of ideas and its clouding over and starting to get darker :surrender:
starting to wish I'd gone to a garage now!!
It will just be tight mate.
Gently hammer a blade between the friction material and the rotor.
Remember that it has to come out square so you may have to work at it a little bit.
Alex.
Hi mate i am not far away from you at all so if you fancy a hand, in exchange for a bre i will pop down and give you a hand ! You got everything else you need ? copper slip etc ??
Coops
Coops
thanks for the offer mate :thumbs:
I decided to ignore it all day today and have another crack tomorrow. it's just the one pad and all others have been replaced fine. I'll try slide a blade in like Alex recommended but I'll let you know if that also fails!
  • 3 weeks later...
decided to have another look at my brakes tonight and finally freed the stuck pad - only took 40mins of me pounding it with a hammer and screwdriver but the bugger is finally off!
Went to do the other side and it was all sorted in 5 mins so at least I know that it's within my limited mechanical abilities to change brakes in future - next step is to change the discs myself :wacko: (thankfully should be a while before there ready for swapping!)
Make sure you put a generous amount of copper grease.
Come to think of it, I would acute sand off the corrosion and rust and give the whole calliper a clean since the whole brake i8s exposed
dont use the grease on the cylinder now u hear. use brake fluid to grease up the sides of the cylinder and clean it before you push it back into the calliper!
