tre50 Posted March 24, 2010 Posted March 24, 2010 Hey guys i just joined today so sorry if this is the wrong spot to post this question but as we all know with irs our cars like to wheel hop sometimes, jw wondering what is a good mod to help prevent that and also what exactly can wheel hop break on our cars Quote
drob Posted March 24, 2010 Posted March 24, 2010 wheel hop, i take it you mean wheel spin, the key to good traction is decent tyres. If your running standard bridgestone re040 tyres this should be your first priority to get some decent rubber as everyone will agree the bridgestones on this car are rubbish Quote
tre50 Posted March 24, 2010 Author Posted March 24, 2010 no i meant wheel hop its from when your tires lose than regain traction sometimes depending on the road or what rpm u launch your car in that happens Quote
drob Posted March 24, 2010 Posted March 24, 2010 what tyres do you have on, how much tread is left on them and what psi is in your tyres can all cause your problem Quote
Stew Posted March 24, 2010 Posted March 24, 2010 Not a term I'm familiar with. Did a quick search and uncovered some reading for later. This what you mean? http://www.youtube.com/watch?v=DOVtnAZYBgM&feature=fvw Not something I've seen before and everything I read (quickly) was pointing at very aggressive and not being very mechanically sympathetic to your car. Quote
tre50 Posted March 24, 2010 Author Posted March 24, 2010 they're the stock 245 bridgestone potenza's and they only have about 2000 miles on them and they're kept at 40 psi, i've been told though that a stiffer suspension and urethane bushing kits can help keep the wheels planted on the ground Quote
Stew Posted March 24, 2010 Posted March 24, 2010 they're the stock 245 bridgestone potenza's and they only have about 2000 miles on them and they're kept at 40 psi, i've been told though that a stiffer suspension and urethane bushing kits can help keep the wheels planted on the ground what miles has your car (specifically the suspension components) done? Do you regularly launch the car or do burnouts and stuff? The Potenzas when cold might not be helping to be honest if they are 040s. They aren't that good in anything but warm weather. The 050s are much better though. Quote
tre50 Posted March 24, 2010 Author Posted March 24, 2010 yeah thats usually when it happens if they're cold they will hop at times and the car only has 22000 miles so i know everything else is fine. what im planning on doing is ordering some urethane bushings putting my 245's up front and ordering 275's for the rear Quote
drob Posted March 24, 2010 Posted March 24, 2010 40psi is a tad high, should be 35psi if there 18's could be why it bobs about if your tyres have that much air in them Quote
introspect Posted March 24, 2010 Posted March 24, 2010 they're the stock 245 bridgestone potenza's and they only have about 2000 miles on them and they're kept at 40 psi, i've been told though that a stiffer suspension and urethane bushing kits can help keep the wheels planted on the ground Should be 35psi for stock wheels and tyres Quote
Bradders Posted March 24, 2010 Posted March 24, 2010 they're the stock 245 bridgestone potenza's and they only have about 2000 miles on them and they're kept at 40 psi, i've been told though that a stiffer suspension and urethane bushing kits can help keep the wheels planted on the ground Should be 35psi for stock wheels and tyres That's what it says on the door shuts. Surely Nissan are right with this? Or am I put too much faith in them TRE50 I must say it sounds like you are canning the car rather hard. Are you talking it to RWUB's?? Bradders. Quote
Greekman Posted March 24, 2010 Posted March 24, 2010 I know what he means...mine does the same when you wheelspin on wet tarmac...and yes bushings supposedly help but cant confirm yet...its got nothing to do with the tyres...its when the rear axle is hoping like a rampant rabbit ps tyre pressure at 35...40 is for lorries!!! Quote
ZMANALEX Posted March 24, 2010 Posted March 24, 2010 To over come this problem on the Zed I fitted adjustable anti-tramp bars to mine. Anti-tramp bars effectively stop the back axle from ‘hopping’ under hard acceleration. Running the REO40s at 40psi certainly will not help and neither will giving it beans before the rubber is up to temp. I run 600bhp and experience no hop at all from the rear axle when getting the power down. Alex. Quote
Greekman Posted March 24, 2010 Posted March 24, 2010 To over come this problem on the Zed I fitted adjustable anti-tramp bars to mine.Anti-tramp bars effectively stop the back axle from ‘hopping’ under hard acceleration. Running the REO40s at 40psi certainly will not help and neither will giving it beans before the rubber is up to temp. I run 600bhp and experience no hop at all from the rear axle when getting the power down. Alex. Now why are you doing this to me??? let me try adam's bushings first and then i ll get in touch with you... Quote
bronzee Posted March 25, 2010 Posted March 25, 2010 they're the stock 245 bridgestone potenza's and they only have about 2000 miles on them and they're kept at 40 psi, i've been told though that a stiffer suspension and urethane bushing kits can help keep the wheels planted on the ground Should be 35psi for stock wheels and tyres That's what it says on the door shuts. Surely Nissan are right with this? Or am I put too much faith in them When I was having many issues with my Zed, one of the things we did was go back to the importer of the tyres, and they totally verified 35psi is the correct pressure to run at. Even with 2k on the tyres, they must be showing a tiny bit of centre wear? Quote
