tyre nosy when turning right!!!
I had new front tyres fitted about 3 motnsh ago toyo T1-R.They were no problem up until about a month ago when i notice taking right hand corners was a lot noiser than taking left hand corners....do you guys have any ideas what this could be?
possibly lost a wheel weight, might need rebalancing, or the camber might be out,
just get the camber toe and wheel alignment and blanacing checked. alot of places won't charge for an alignment test unless you need it adjusting. ;)
because your putting that bearing under increased load with the lateral force of turning in that direction. ;)
good test for a wheel bearing is when parked get hold of the top of the tyre and give the wheel a good shake if you can feel movement backwards and forwards then the wheel bearing is on its way out. ;)
I tried that but i didnt feel to much movement. I am starting to think the bearing has gone...i am wondering if the torlerances are so tight that even the smallest amount would mean it on its way out....Any ideas on the cost of a new one or are the adjustable?
ok, so a small update!! The noise is a rumble, this actaully happens while going straight but get worse turning right but completely go's when turning left. Do people believe that this is still the bearings?
IMO no i don't think so if it was the bearing it would be more of a groan or whine than a rumble. i may be tempted to get the wheel rebalanced as you may have lost a weight.
whats the tyre wear like on the wheel, is it even or is it more worn to one side. might be need adjustment. also check the tyre for any blisters or bulbous sections, especially on theinside of the tyre wall where you cant see.
The tyre wear is good, no feathering at all. I stopped off at the place that fits my tyres (has done foe years) and they couldn't see anything wrong with them at all. Might jack up the front over the weekend and have a look!! Its also going into TMG for a P1 so i'll ask them to have a look as well.
I'm out of ideas nearly. I vaguly remember someone else having a noise issue and it was so
ethong to do with there susspension, but that was more a knocking noise. Without being in the car it's very hard to diagnose anything. When you go back tomorrow it might be worth taking one of the fitters for a drive and see if he can hear it.
