ab350z Posted May 18, 2009 Posted May 18, 2009 Folks, hopefully someone can shed some light on a strange problem i'm having with my drivers electric window. It has recently started misbehaving. When I've been out in the car, stop, key out of the ignition, open door, get out of the car then shut the door to lock it, the window comes down a couple inches. So i have to open the door, put the window back up, close the door again. Sometimes it stays up, other times like last night, it takes 10-12 attempts, before I eventually have to climb out of the passenger side!! Didnt happen at all this morning, just stayed up when I closed the door. There's no common factor I can see either, happens if the window has been up the whole journey or if its been down at all. Random Quote
ab350z Posted May 18, 2009 Author Posted May 18, 2009 Have you tried to do a window reset bud. Didn't know there was such a thing. Can you point me in the right direction? Quote
IanS16 Posted May 18, 2009 Posted May 18, 2009 http://www.350z-tech.com/zwiki/Service: ... _Procedure Quote
nixy Posted May 18, 2009 Posted May 18, 2009 this happened to mine a few months back as well. Martin told me the procedure of ignition, door open, windows down etc and it's been fine since. Quote
nixy Posted May 18, 2009 Posted May 18, 2009 http://www.350z-tech.com/zwiki/Service:TSB_04-089_Window_Regulator_Motor_Reset_Procedure i did something else less complicated martin showed me, can't remember what now............just an ignition and windows up door open procedure. Worked for me. MARTIN!!!! Quote
martinmac Posted May 18, 2009 Posted May 18, 2009 Reminder, teach Nixy to use the search button. viewtopic.php?f=10&t=16671&hilit=+window Quote
nixy Posted May 18, 2009 Posted May 18, 2009 martin, i had you washing my car on saturday, do you really think i'm going to search for posts? Quote
martinmac Posted May 18, 2009 Posted May 18, 2009 Sorry about the delay in replying, I was doing some ironing Quote
ab350z Posted May 18, 2009 Author Posted May 18, 2009 Any that doesnt involve removing the door card? Quote
nixy Posted May 18, 2009 Posted May 18, 2009 i definitely never removed the door card but i can't remember what i did.....................it was a process of ignition, doors open/closed windows/up down. Somebody told me and i THOUGHT it was martin.......... Quote
luv2andy Posted May 20, 2009 Posted May 20, 2009 Hi---I am new to this forum---as my z has developed the electric window saga---sometimes it will not self-close or open when shutting the door. I can see various problems with these windows and presume there is acommon fault? My car is an import and lo---the fuses are marked in Japanese. Any help would be grateful. I have to keep closing the door with the window hitting the b post. Then next day--it is ok. Am I a complete idiot here? I do hope so? Thank you in advance for your help? Andy. Quote
M13KYF Posted May 20, 2009 Posted May 20, 2009 Hi---I am new to this forum---as my z has developed the electric window saga---sometimes it will not self-close or open when shutting the door. I can see various problems with these windows and presume there is acommon fault? My car is an import and lo---the fuses are marked in Japanese. Any help would be grateful. I have to keep closing the door with the window hitting the b post. Then next day--it is ok. Am I a complete idiot here? I do hope so? Thank you in advance for your help? Andy. try the window reset procedure found in the guides section Quote
martinmac Posted May 20, 2009 Posted May 20, 2009 There you go Andy. http://www.350z-tech.com/zwiki/Service:TSB_04-089_Window_Regulator_Motor_Reset_Procedure Quote
AK350Z Posted May 20, 2009 Posted May 20, 2009 Thank you Mike. What is the guides system? Don't worry, i'll take this one.... HERE: http://www.350z-uk.com/forum/viewforum.php?f=35 EDIT: Snap! Quote
luv2andy Posted May 20, 2009 Posted May 20, 2009 thank you ak. I linked to the forums pages and it is a s bad as trying to decipher the problem. You may be all very savvy and site-conscious but I am ignorant. I press the switch it no work. I press the switch it work. I ask the question you give me reference. I cannot find the elusive guide. Can you please be a little more specific and point me in the exact place I need to be?I do not have sat nav to navigate this site and as stated I am probably more ignorant than the average and un-savvy as to the peculiarities of the site I am trying to negotiate. Shall I ring up Nissan ? Will my life be any easier? Please tell me that Nissan Motors are NOT incapable of fitting electric windows? Why is there not a manual overide? Please step in again and help. Quote
luv2andy Posted May 20, 2009 Posted May 20, 2009 The window regulator motor reset procedure link does not work? Is this intermittent as well? Quote
luv2andy Posted May 20, 2009 Posted May 20, 2009 Ok I got it. Now all I need to do is ruin my beautiful clean/unmarked door panel and put some scratches in it. Innit. By the way how the what does that item fall off?? Quote
martinmac Posted May 20, 2009 Posted May 20, 2009 There you go bud. This place is pretty addictive and was my first forum too. Look what happened viewtopic.php?f=35&t=21801 Quote
luv2andy Posted May 20, 2009 Posted May 20, 2009 You see-----when in trouble or in doubt---sort the biggest bastard out. Perfect---door panels nicely photographed by a genius for the useless minded ham fisted technically bereft OLD flyers. Thank you for the INVALUABLE link to that===and the reset manual. All Ineed to do now is to get you round here...............Just flew back from Normandy--did 150 miles in 2 hrs---with peage and 12 miles of road to the m/way--didn't see a Gendarme--------- Quote
martinmac Posted May 20, 2009 Posted May 20, 2009 Thats why we like thses guides Andy, they make us look clever Quote
luv2andy Posted May 20, 2009 Posted May 20, 2009 Clever soft if you ask me. I fear that some form of snobberry is attached to these forums. Try the rolls royce enthusiast club if you dare. Now with that in mind and "attention to detail" viz---you may have overlooked my initial enquiry? ref---japanese fuse box. SO if I am one day able to discern the specific fuse, take it out, and put it back in again, will this not therefore have the effect of resetting the mech?? Or is that too too clever as well??? Do I have to labour under the door panel deal? Or is this suggestion just linear or lateral thinking? There is more ways to murder cats for eating. (please remember the pen is mightier than the sword) Quote
luv2andy Posted May 20, 2009 Posted May 20, 2009 If you really want to look clever---put in the apostrophes in the appropriate places. Otherwise you look thick. Quote
