ersen.o Posted January 11, 2009 Posted January 11, 2009 Hey, im looking to buy some new rims, 8.5 front and 9.5 rear +25ET each? is thsi fine also i dont like super low profile tyres, i want at least 40 profile all around so atm i have 225/50/17 rear 255/45/17 rear with that calculator i have come to the closest match being front 255/40R18 +0.7 bigger or 245/40R18 -0.55 smaller rear 275/40/18 +1.54% bigger (265/40/18 dont exist) are these sensible sizes? i saw big phils azure 350 with the rotas and it looked like it had the perfect thickness, what whas he running? Quote
ersen.o Posted January 11, 2009 Author Posted January 11, 2009 hers my choices: Tyre code Diameter Circumference Difference ---------- -------- ------------- ---------- 285/35 R18 657 mm 2064 mm -1.51 % 295/35 R18 664 mm 2086 mm -0.46 % 255/40 R18 661 mm 2077 mm -0.84 % 265/40 R18 669 mm 2102 mm 0.36 % <--------dont exist 275/40 R18 677 mm 2127 mm 1.56 % <---? just right? Quote
ersen.o Posted January 11, 2009 Author Posted January 11, 2009 235/40 R18 645 mm 2026 mm -1.77 % 245/40 R18 653 mm 2051 mm -0.55 % <---------------- 255/40 R18 661 mm 2077 mm 0.67 % <---------------- 225/45 R18 660 mm 2073 mm 0.44 % not wide enuf 235/45 R18 669 mm 2102 mm 1.81 % front Quote
Martin W Posted January 11, 2009 Posted January 11, 2009 Hey, im looking to buy some new rims, 8.5 front and 9.5 rear +25ET each? is thsi fine also i dont like super low profile tyres, i want at least 40 profile all around so atm i have 225/50/17 rear 255/45/17 rear with that calculator i have come to the closest match being front 255/40R18 +0.7 bigger or 245/40R18 -0.55 smaller rear 275/40/18 +1.54% bigger (265/40/18 dont exist) are these sensible sizes? i saw big phils azure 350 with the rotas and it looked like it had the perfect thickness, what whas he running? I think IanS16 has this now - try searching Rays fitted by Nissan (18") have 45 profile 225/45 front on 8" 245/45 on 8.5" Quote
ersen.o Posted January 12, 2009 Author Posted January 12, 2009 thanks, decided togo for: Lenso D1R 18x9 - 275/35/18 +25 Lenso D1R 18x10 - 295/35/18 +25 Quote
Martin W Posted January 12, 2009 Posted January 12, 2009 thanks, decided togo for: Lenso D1R 18x9 - 275/35/18 +25 Lenso D1R 18x10 - 295/35/18 +25 Didn't think they went that wide ? How much? all in Quote
rickya Posted January 12, 2009 Posted January 12, 2009 On a 8.5 front and 9.5 rear alloy with +25ET offset I would go: Front: 245/40/18 or 235/40/18 Rear: 275/40/18 I would'nt go 18x9 on front, it will spoil ride with understeer & unnecesary weight. Especially then running 275 width tyres on front[/b] Quote
S1 HNK Posted January 12, 2009 Posted January 12, 2009 +1 i would say 275 on the front and 295 is too wide and will spoil the handling Quote
ersen.o Posted January 12, 2009 Author Posted January 12, 2009 you think? only reason i went for that is as this guy sed it was perfect and it looks amazing: http://forums.nicoclub.com/zerothread?id=359495 Quote
Sarnie Posted January 13, 2009 Posted January 13, 2009 thanks, decided togo for: Lenso D1R 18x9 - 275/35/18 +25 Lenso D1R 18x10 - 295/35/18 +25 Quote
Chris`I Posted January 13, 2009 Posted January 13, 2009 you think? only reason i went for that is as this guy sed it was perfect and it looks amazing: http://forums.nicoclub.com/zerothread?id=359495 They dont say how well they ride, just that they look good. To me that seems too wide, but if you can get away with it why not! Be a trend setter. Let us know how it handles Quote
ersen.o Posted January 13, 2009 Author Posted January 13, 2009 yeah maybe i will go thinner on the front but i really wanted to try the 295 on the rear maybe i will got for 8.5 fronts with 245-255 / 40's ill have a look into it theyre only 150 each on camskill for toyos, which aint that bad Quote
Chris`I Posted January 13, 2009 Posted January 13, 2009 yeah maybe i will go thinner on the front but i really wanted to try the 295 on the rear maybe i will got for 8.5 fronts with 245-255 / 40's ill have a look into it theyre only 150 each on camskill for toyos, which aint that bad Only problem with staying thin on the front and wide on the rear is that you will get more understeer. Depends how you like the car balance to feel really. Quote
Digsy Posted January 13, 2009 Posted January 13, 2009 The guy who's done this doesn't seem to mention whether he had to roll his arches. Be prepared to do this if you're going that wide front and rear. Quote
ersen.o Posted January 13, 2009 Author Posted January 13, 2009 ok u guys were right lol, i did sum research and even sumo power 600bhp 350z dont run that wide lol so this is what i have decided 8x18 - 245/40/18 ET25 10x18 - 275/40/18 ET25 wot you think? theyre both about 0.5% out too which is the closest i could get thx for advice! Quote
marzman Posted January 14, 2009 Posted January 14, 2009 ok u guys were right lol, i did sum research and even sumo power 600bhp 350z dont run that wide lol so this is what i have decided 8x18 - 245/40/18 ET25 10x18 - 275/40/18 ET25 wot you think? theyre both about 0.5% out too which is the closest i could get thx for advice! +100 that sounds good to me. Although if you're staying 18" and running 40 profile, you may need to lower the car as the wheels could look a bit swamped? Quote
Sarnie Posted January 14, 2009 Posted January 14, 2009 Much more like it PS: Why aren't you just jumping to 19's? Quote
