jim Posted August 19, 2008 Posted August 19, 2008 Hi all - got a set of gas bonnet lifters from Phil today but haven't a clue how to fit them. I've PMd Phil but you know how busy he usually is and it could be a while before I get a reply. Can anybody else who has done this provide any guidance or pictures? Quote
martinmac Posted August 19, 2008 Posted August 19, 2008 Good point Jim, getting some fitted tomorrow so will take some pics. Which doesnt help you today Quote
dcash5 Posted August 19, 2008 Posted August 19, 2008 On the plastic covers u will see a D shaped raised part, cut out this to reveal one of the wing bolts, this needs to be replaced by one of the ball headed bolts, the black bracket needs to fixed onto the bonnet catch, and the secondary ball headed bolt horrisotally through the final hole, pictures tell 1000s works, (Phil sent me these to help me) Quote
jim Posted August 19, 2008 Author Posted August 19, 2008 That seems to be a great help, though I'm not sure I can see exactly how the brackets fit on to the hinge brackets. I'll go and have another look. Thanks. Quote
jim Posted August 19, 2008 Author Posted August 19, 2008 Had another look - the struts I have seem to be quite different from the ones in the photos. The fitting on the narrow end of the strut already has a right-angled bracket attached to it, which I assume should be attached to the bolt under the plastic trim. I can't however, see where to attach the black bracket - it comes with two hex bolts which don't seem to fit anywhere. Now I'm really baffled! Quote
jim Posted August 19, 2008 Author Posted August 19, 2008 Good point Jim, getting some fitted tomorrow so will take some pics. Which doesnt help you today I'm in no hurry, so the pictures will be much appreciated. Thanks. Quote
bigphil Posted August 19, 2008 Posted August 19, 2008 ring me on the mobile Jim and all will become clear 07714457051 Quote
jim Posted August 19, 2008 Author Posted August 19, 2008 Thanks, Phil - struts now installed and working perfectly. It was easy once I got the brackets the right way round! Thanks again for talking me through it. Quote
bigphil Posted August 19, 2008 Posted August 19, 2008 Thanks, Phil - struts now installed and working perfectly. It was easy once I got the brackets the right way round! Thanks again for talking me through it. No problem Quote
RobD7 Posted August 23, 2008 Posted August 23, 2008 These look good, although from reading above, would I have to do some cutting!?!? Quote
martinmac Posted August 23, 2008 Posted August 23, 2008 Just a bit of rubber bud. Lower mount with the rubber cropped. Upper mount. Quote
bigphil Posted August 23, 2008 Posted August 23, 2008 These look good, although from reading above, would I have to do some cutting!?!? only a small amount to the plastic trim. Quote
RobD7 Posted August 23, 2008 Posted August 23, 2008 Ok cool, thanks guys. Will have a look under the bonnet when I get home and make a decision Quote
GIXXERUK Posted August 23, 2008 Posted August 23, 2008 Ok cool, thanks guys. Will have a look under the bonnet when I get home and make a decision easy fit mate and the cutting is only to bits of plastic the size of a 1 pence coin Quote
RobD7 Posted August 23, 2008 Posted August 23, 2008 Ok cool, thanks guys. Will have a look under the bonnet when I get home and make a decision easy fit mate and the cutting is only to bits of plastic the size of a 1 pence coin Cool thanks Could well be the next purchase Quote
