shooter89 Posted July 8, 2025 Posted July 8, 2025 Hi all, I'm quite familiar with 370Zs, but I'm currently dealing with an issue I can't figure out. The cruise control buttons aren't working at all, while the volume controls function just fine. I've removed the airbag to inspect the connections, and everything appears to be properly connected with no visible damage. I also tried to locate a fuse related to cruise control but couldn’t find one. Does anyone know what might be causing this? Or could point me to which fuse (if any) controls the cruise control system? Thanks in advance! Quote
SWoMP Posted July 9, 2025 Posted July 9, 2025 This may sound unlikely but I had a similar problem. Have you made sure your left foot is totally off the clutch pedal when trying to engage CC. Apologies, if you've already done that, but worth a mention... Quote
shooter89 Posted July 9, 2025 Author Posted July 9, 2025 17 hours ago, SWoMP said: This may sound unlikely but I had a similar problem. Have you made sure your left foot is totally off the clutch pedal when trying to engage CC. Apologies, if you've already done that, but worth a mention... I can confirm I tried with my foot off the clutch also removed the cable and attached to the sensor and then put it back on. I wonder if the switch is dead but I see no cruise control lights on the dash when i press the button, like it does not exist. Quote
Stewal Posted July 13, 2025 Posted July 13, 2025 Clutch and brake pedal switches are a good place to start. Then scan with a code reader: traction control, eml, abs faults etc usually disable cruise but would expect a dash warning light too...... Quote
Wolf24h Posted July 13, 2025 Posted July 13, 2025 Push the clutch or brake pedal upwards when trying to turn the CC to see if the switches are the reason Quote
shooter89 Posted July 14, 2025 Author Posted July 14, 2025 (edited) On 13/07/2025 at 15:08, Stewal said: Clutch and brake pedal switches are a good place to start. Then scan with a code reader: traction control, eml, abs faults etc usually disable cruise but would expect a dash warning light too...... On 13/07/2025 at 19:45, Wolf24h said: Push the clutch or brake pedal upwards when trying to turn the CC to see if the switches are the reason Thanks Stewal and Wolf24h, I will have a go once I fix the Concentric Slave Cylinder Tube bleed nipple, the clutch fluid was dirty so I wanted to bleed the system but end up damaging the bleed nipple, the threads are damaged ordered 6mm bleed nipple going to attempt repairing the thread on the pipe and fit the nipple fingers crossed if unsuccessful the transmission needs to come out if im not wrong. Edited July 14, 2025 by shooter89 Quote
