James Scott-Stacey Posted October 13, 2022 Share Posted October 13, 2022 Hello all,  I've stripped down a rev-up engine and need two valves to get it back up and running. So a few of questions. 1) Where can I buy the parts for a reasonable price for the engine? (Two exhaust valves, the gasket kit, water pump). 2) IS there anything I should be specifically looking out for when rebuilding the engine (e.g. any thing I should be specifically replacing apart from the usual. 3) Does anyone have the workshop pdf with engine rebuild instructions for bolt order and torque specs to save me trawling the internet for hours.  Any other tips at all would be hugely appreciated. Can't wait to get it back together. Quote Link to comment Share on other sites More sharing options...
BurnedSparkPlug Posted October 14, 2022 Share Posted October 14, 2022 Hello there, which gasket kit u went for? I'm be doing rebuild soon on my 350z 03'. I saw Victor Reinz and Ishino Stone is cheaper then OEM any info on thouse or any other gasket kits? Alex Quote Link to comment Share on other sites More sharing options...
Coz@TORQEN Posted October 14, 2022 Share Posted October 14, 2022 Hi James,  We have gasket kits available here: https://www.torqen.uk/nissan/350z/engine/gaskets/9039-350z-de-ishino-stone-oem-engine-rebuild-gasket-kit-jfs-00641.html  If I remember correctly, one or two of the gaskets are slightly different to the standard DE so you may need to order those seperately. Nissan do a Rev-up kit but it'll be super expensive compared to the Ishino one.  Exhaust valves: https://www.torqen.uk/nissan/350z/engine/valves-retainers-springs/27599-350z-de-nissan-oem-13202-8j10a-exhaust-valve-13202-8j10a.html  Water pump: https://www.torqen.uk/nissan/350z/cooling/water-pumps/26901-350z-de-hitachi-oem-replacement-water-pump-assembly-wup0038.html  The factory service manual can be found here: https://www.nicoclub.com/service-manual?fsm_download=350Z/Coupe/2005/em.pdf  Let me know if you need anymore help! Quote Link to comment Share on other sites More sharing options...
Coz@TORQEN Posted October 14, 2022 Share Posted October 14, 2022 2 hours ago, BurnedSparkPlug said: Hello there, which gasket kit u went for? I'm be doing rebuild soon on my 350z 03'. I saw Victor Reinz and Ishino Stone is cheaper then OEM any info on thouse or any other gasket kits? Alex  Hi Alex,  Both Ishino Stone and Victor Reinz are really good quality kits, made in Japan.  We have Ishino stone in stock, linked above and on sale at the moment if you need one. Quote Link to comment Share on other sites More sharing options...
Cosmic73 Posted October 8, 2023 Share Posted October 8, 2023 On 14/10/2022 at 10:55, Coz@TORQEN said: Hi James,  We have gasket kits available here: https://www.torqen.uk/nissan/350z/engine/gaskets/9039-350z-de-ishino-stone-oem-engine-rebuild-gasket-kit-jfs-00641.html  If I remember correctly, one or two of the gaskets are slightly different to the standard DE so you may need to order those seperately. Nissan do a Rev-up kit but it'll be super expensive compared to the Ishino one. Hey Coz, Could you tell me more about this 'rev-up' kit please? I'm stripping down my 2006 Z which was advertised as a rev-up, which I assumed was some form of special edition, but the HR (high rev engine) was standard. Does this mean rev-up and HR engines are different and Ill need an super expensive rebuild kit Thanks, Neil Quote Link to comment Share on other sites More sharing options...
Cosmic73 Posted October 8, 2023 Share Posted October 8, 2023 6 minutes ago, Cosmic73 said: Hey Coz, Could you tell me more about this 'rev-up' kit please? I'm stripping down my 2006 Z which was advertised as a rev-up, which I assumed was some form of special edition, but the HR (high rev engine) was standard. Does this mean rev-up and HR engines are different and Ill need an super expensive rebuild kit Thanks, Neil Wish I knew how to edit my previous post.... After a bit of Google research I think there were 3 engine types DE, DE rev-up and HR, So am I right in thinking my 2006 is a DE rev up and that's the super expensive kit I need? Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted October 8, 2023 Share Posted October 8, 2023 22 minutes ago, Cosmic73 said: Wish I knew how to edit my previous post.... After a bit of Google research I think there were 3 engine types DE, DE rev-up and HR, So am I right in thinking my 2006 is a DE rev up and that's the super expensive kit I need? You are correct about engine types. Â The HR engine is completely different to the DE and DE rev-up and came out in 2007. Â An HR engined car has the bonnet bulge. Â AFAIK, to get a car from DE rev-up to HR is impossible. HTH 1 Quote Link to comment Share on other sites More sharing options...
Cosmic73 Posted October 8, 2023 Share Posted October 8, 2023 4 hours ago, ATTAK Z said: You are correct about engine types.  The HR engine is completely different to the DE and DE rev-up and came out in 2007.  An HR engined car has the bonnet bulge.  AFAIK, to get a car from DE rev-up to HR is impossible. HTH Thanks 🙂 Quote Link to comment Share on other sites More sharing options...
