350Z Rear Calipers, RTS Front Disks, Orange Stuff Front Pads
£225 for rear calipers.
£60 for front brake disks.
£50 for front brake pads.
Front calipers are SOLD
Rear Disks are SOLD
Rear Pads are SOLD
Discs and pads have had little use probably around 5000 miles. No lips on any of the disks. Some corrosion because the car was stood for around 12-15 months before being broken but this will clean up once used again.
Brake pads have lots of life left as can be seen in the pictures.
Disks cost about £375 new
Pads about £250 new
All caliper bleed screws have been removed and regreased, none are seized. Pistons checked for free movement all check out ok without issue.
Can get more pictures if anyone needs any.
Collection from Huddersfield or will post at buyers expense and risk.
20210317_200910
20210318_184131
20210318_183955
20210318_184032
Edited by SteveW
  • SteveW changed the title to 350Z Complete Brembo Brake Set Up
  • SteveW changed the title to 350Z Complete Brembo Brake Set Up £600
  • SteveW changed the title to 350Z Brembo Brakes now splitting Calipers, Disks, Pads
May well be interested in the discs. They're clearly not OEM because of the grooves, do you know the brand? The £375 new for the discs, was that the whole set or just one axle?
Thanks
Thanks
They are RTS disks bought from Tarmac  a few years ago. Looks like price has gone down a bit now they are £318 now for front and rears.
https://www.tarmacsportz.co.uk/rts-performance-350z-02-08-front-brake-discs.html
OK thanks for that. It's the rears that are giving me a problem (vibration) at the moment, so if you would send me the discs and pads for the back axle it should sort the problem or at least help narrow down the issue.
If you can message me with your details I'll sort payment tomorrow.
Hope that you're able to sell the rest.
  • SteveW changed the title to 350Z Rear Calipers, RTS Front Disks, Orange Stuff Front Pads
  • 8 months later...
I have a set available if these are gone.
Paul
6 hours ago, Shunter8 said:
Interested in the rear calipers if they’re by any chance still available?
  • Thanks 1
  • 1 month later...
Paul
@P15UL T
Can you pm me, I think you inbox is full.
@SteveW sent you a PM about the rear calipers too but Shunter8 should have first dibs.
2 hours ago, Oggieteepo said:
@P15UL T
Having unexpectedly taken on another car alongside my Stagea my brake upgrade plans are currently on the back burner so have at it if either set are still available 👍
  • Thanks 1
