pwes Posted January 2, 2021 Posted January 2, 2021 Hi guys, my 370z has been sitting for just over a year while out of the country. Friends started it last July Just jump started it and it fired up after a moment or three, but with an instant smell of plastic/ rubber and a fair amount of smoke from the left side of engine as you look from the front. Main belt can be seen going round, but I suspect maybe something like water pump wheel may be siezed, therefore creating smoke, does this sound right or any suggestions? No idea if temp will be correct as I turned it off before it got to temp, litterally within 20 of starting, before we get a fire Suggestions and things you would check please! Thanks Quote
andy james Posted January 2, 2021 Posted January 2, 2021 Sounds like something to do with the auxiliary belt as it goes around a lot of pulleys. Have a good down the front of the engine for anything obvious. Quote
