Wanted: 370z Axle Nut Cap
Hi, i am after a replacement rear axle nut cap (and cotter pin).
Does anyone know what the part number is or where i could purchase one?
I found the USA part number which is 40263-1CA0A but i cant find the UK part number.
Here are some pictures of the part.
Any help in finding one would be appreciated.
is that because of the axle click noise?
I am also doing mine now but decided to go the Kawasaki axle nut way
@ZMANALEX can you please send me also a pm if you do the oem cotter pins (x2) and oem spring washers (x 2) ,370z gt 2010
What spring washer are you referring to?
I think there is a spring washer (40037-1CA0A) that goes on before the nut and apparently when using the kawasaki nuts an extra one on each side is needed to bring the nut forward a bit(I am reusing the ones I already have on there but need an extra 2),hope it makes sense
