Grmagnum Posted October 29, 2020 Posted October 29, 2020 Hi, Guys, can anyone help ? I need new front discs and pads , when checking all say 324mm however mine measure 330mm and on brembo calipers. Question is can I fit 324mm ? Regards George Quote
Azurez33 Posted October 29, 2020 Posted October 29, 2020 You should be able to pop your reg in and it will confirm the product? also what brand are you buying because that will also be a good indicator, if you’re buying brembos I believe the discs are the same from 03-07 so I guess the hr has slightly bigger discs Quote
pintopete58 Posted October 29, 2020 Posted October 29, 2020 Hi bud 323 / 324 is fine when your measuring do you measure off the 100mm line Quote
Grmagnum Posted October 29, 2020 Author Posted October 29, 2020 It was registered 2007 but 2006 DE model , it's a gt with brembo calipers and discs measured 330mm from one side to other diameter. I don't know if these are the original or not ! Not sure what the 100mm line is? Quote
Grmagnum Posted October 29, 2020 Author Posted October 29, 2020 I think I will take the discs off and re- measure maybe i got it slightly wrong. Hopefully!! Thanks for your answers guys. Quote
HEADPHONES Posted October 29, 2020 Posted October 29, 2020 I ordered brembo discs and pads from carparts4less last year. Here's my order numbers if it helps Quote
HEADPHONES Posted October 29, 2020 Posted October 29, 2020 (edited) They often have offers on so depending on when you order, the price varies After discount I paid £327 for front and back discs and pads Edited October 29, 2020 by HEADPHONES Quote
