EvansJD2112 Posted October 9, 2019 Posted October 9, 2019 Hi Noticed this week that my passenger window is not returning when closing the door. 99% of the time, it's just me in the car so very rarely is the door opened. No probs I thought, just do the reset - done a few times on my last 370z and the 350z before. This time, damned if I can get it to work. Tried the fully up, fully down, hold 3s, fully up (as per the manual) Tried the fully up, hold 15s, fully down, hold 15s, fully up ...and various others I've found with Google (all with ignition ON rather than engine running) The procedures definitely do something - sometimes the window stays up when opening the door (ouch), other times stay down and I have to hold the button to close. Before I resort to getting the car booked in... any suggestions ? 2018 GT Auto thanks Quote
EvansJD2112 Posted October 9, 2019 Author Posted October 9, 2019 Edit.. Also just tried below. Had to reset the drivers window after disconnecting battery, that was ok. Passenger window still refusing to play ball. ADDITIONAL SERVICE WHEN REMOVING BATTERY NEGATIVE TERMINAL : Special Repair Requirement INFOID:0000000004460995 The following specified operations cannot be performed under the non initialized condition. • Auto-up operation • Anti-pinch function • Key cylinder switch power window function • Automatic window adjusting function INITIALIZATION PROCEDURE 1. Disconnect battery negative terminal or power window switch connector. Reconnect it after a minute or more. 2. Door switch is OFF (close). 3. Turn ignition switch ON. 4. Operate power window switch to fully open the window. (This operation is unnecessary if the window is already fully open.) 5. Continue pulling the power window switch AUTO-UP. Even after glass stops at the fully closed position, keep pulling the switch for 3 seconds or more. 6. Initializing procedure is completed. Quote
nicreed262 Posted July 8, 2023 Posted July 8, 2023 hello, did you ever find the fix for this? dealing with the same problem. cheers Quote
Matay20 Posted July 9, 2023 Posted July 9, 2023 Hi, process should work. turn ignition on, don’t start the engine. open window and keep button down for a few seconds close window and keep button up for a few seconds worked for me following a flat battery Quote
ShortPaul Posted July 9, 2023 Posted July 9, 2023 As Matt said but hold the switch in the down position for 20 seconds then close to the window and again repeat and keep the switch in the up position when the window is in closed position,this should sort it. Quote
